Slight 'Pinging' Off Idle
Old Sep 25, 2019 | 06:43 PM
Ray Romano's Avatar
Ray Romano
Default Slight 'Pinging' Off Idle
Do I just retard the ignition timing and dial in the carb? It's a 1970 350/350 engine and I'm using Shell 93 octane. Suggestions? And no, I'm not cutting the piston tops down. lol
Old Sep 25, 2019 | 08:32 PM
mike914's Avatar
mike914
Hello Ray
In a word....Yes
I bought a digital timing light.
It was worth the money
I had to dial back to 34 advance before vacuum at 3300 RMP to avoid pinging.
The readout really helped me fine tune it in.
Good luck
Old Sep 25, 2019 | 09:00 PM
lars's Avatar
lars
Make sure your vacuum advance is not providing more than 10 to 12 degrees of additional advance. To see if it's the problem, simply yank the vacuum hose off of it and plug it. If the problem goes away, your vacuum advance is providing too much additional advance and must be limited. If the problem does not go away, you need to retard your initial timing.
Lars
Old Sep 26, 2019 | 06:19 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
try sunoco 93 as well. I had an issue with a station not using 93 in the 93 tank.
Old Sep 26, 2019 | 06:32 AM
derekderek's Avatar
derekderek
it could also be when advance comes in. springs too weak or weights too heavy and you get centrifugal too soon. and springs go soft and bushings disappear.
Old Sep 26, 2019 | 06:34 AM
Jims66's Avatar
Jims66
I have an L79 (11:1 comp.) and use Shell 93. I've also bumped the timing back a hair and tuned the carb a little on the fat side. Re-adjust for summer when heat and humidity increase. Better to be safe than sorry.
Old Sep 26, 2019 | 08:24 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
As stated...go through your advance curve and double check......then check how much the vacuum can is pulling overall. You may need an adjustable vac can which is available from many vendors.
My money is on the vac advance not falling off fast enough.
Is it plugged in to full manifold vacuum?
Jebby
Old Sep 28, 2019 | 04:34 PM
scrappy76's Avatar
scrappy76
I know it's not a Corvette, but wanted to share. If I use regular or midgrade in my truck, I have pinging. Once I put 93 octane in, the pinging goes away. I will be retarding the timing here soon.
Old Sep 28, 2019 | 07:26 PM
Rescue Rogers
Does the truck have a performance motor or do you need the performance of the advance?
Old Sep 28, 2019 | 08:14 PM
cv67's Avatar
cv67
St. Jude Donor '05
Id keep the timing where it should be and use good gas, dont want to give up performance or have it run hot
Old Sep 29, 2019 | 11:52 AM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
If it's pinging slightly off idle,,that's probably the vac advance. Unplug it to see if the pinging goes away. You can limit the vac can to 10 degrees total with a small vac limiter plate from Lars. If that doesn't solve it you'll need to find a diff can so you can change the vac level that it pulls off at.
I had to do a lot of that sort of tuning on my 1970 LT-1 with a blue-printed 11:1 CR. With those vac mods and 32 degrees total it would run fine on 93 octane. But it would also run 30HP stronger with a different tune and about 97-99 octane.
To Slight 'Pinging' Off Idle
