rear spring bolts
Old Oct 2, 2019 | 11:43 AM
mrvette's Avatar
mrvette
Default rear spring bolts
Need two 8" long 9/16 diameter bolts fine thread, and lock nutz, kepnutz......prefer plated for rust prevention.....anyone?? how much $$$
Thanks....
GENE
Old Oct 2, 2019 | 11:58 AM
Crimson Thunder's Avatar
Crimson Thunder
I got mine at the ACE hardware on Blanding down by Gordon Chevy. They always have the "odd" assortment of bolts and nuts.
Old Oct 2, 2019 | 12:05 PM
mrvette's Avatar
mrvette
Thanks, but I went there about a year ago.....no go,.....but you can tell the urgency of this, but one of the bolts/nutz is stripped for some reason....but being ~20 years old, I suppose they are female....
Old Oct 2, 2019 | 01:54 PM
Hammerhead Fred's Avatar
Hammerhead Fred
Thanks....
GENE
These what you're looking for?
PM if interested
Old Oct 2, 2019 | 04:15 PM
MelWff's Avatar
MelWff
Dont they have to be grade 5 or 8 bolts and every Corvette vendor sells them.
Old Oct 2, 2019 | 04:39 PM
mrvette's Avatar
mrvette
I should have known, called Van Steele, they on the way now.....
Old Oct 2, 2019 | 06:09 PM
kodpkd's Avatar
kodpkd
Just make sure you don't over tighten them. When I did mine I got different torque spec's for my 68. Wish I could remember the spec. I think you will be able to tell when you tighten them. I got grade 8 at Lowe's. Also remember,,,,,,,, the height of the rear end is ONLY dependent on the length of the bolt,,,,,, period!
Old Oct 2, 2019 | 06:34 PM
revitup's Avatar
revitup
"Just make sure you don't over tighten them. When I did mine I got different torque spec's for my 68. Wish I could remember the spec. I think you will be able to tell when you tighten them."
Why would these bolts ever be "torqued"?
Old Oct 2, 2019 | 07:20 PM
mrvette's Avatar
mrvette
I agree, they just bolts with much thread, so to adjust ride as wanted.....mine show about 1.5 inches from the nut to the end of bolt, stock ride height so tire looks symetrical in the well opening and frame is square up.....
Old Oct 2, 2019 | 07:23 PM
kodpkd's Avatar
kodpkd
Ops..... Sorry,, my mistake. You are correct. I was thinking about the 4 rear spring hold down bolts. DOH!
To rear spring bolts
