Cooling
Old Oct 2, 2019 | 09:35 PM
bludorbronc's Avatar
bludorbronc
Default Cooling
I have tried everything and I can’t keep the fan out of the radiator. It is a 71, t bar, auto, vintage air, power steering, and it’s pushing a 496, short water pump, 5 blade fan. Can somebody show very good pictures close up of their fan system. I’m about ready to try electric. thanks for your help.
Old Oct 3, 2019 | 07:45 AM
bashcraft's Avatar
bashcraft
Are you saying that the fan is hitting the radiator?
Old Oct 3, 2019 | 02:32 PM
7T1vette's Avatar
7T1vette
The fan blades should be several inches behind the surface of the radiator and the radiator should have a fan shroud on it to FORCE the airflow into the fan. If that's NOT what you have, you need to research the AIM or other configuration documentation to see what components you SHOULD have in that area.
Old Oct 3, 2019 | 02:48 PM
GUSTO14's Avatar
GUSTO14
It would be very helpful to diagnose your issue if you could post a few pictures of what you're looking at.
Good luck... GUSTO
To Cooling
