Loose wheel stud
Old Oct 4, 2019 | 10:26 PM
WARVETT's Avatar
WARVETT
Default Loose wheel stud
When I pulled off my wheels today, I noticed that one of the rear wheel studs was loose. Is this a major problem?
Old Oct 5, 2019 | 08:57 AM
GTR1999's Avatar
GTR1999
well there have been plenty of these cars out there running on 4 studs when one was sheared off with an impact. I like to have all 5 in use though. The studs are knurled to prevent them from spinning. If it was hit it may just be loose, if hit an on angle the hole may be wallowed out.
You can get studs from any vendor or local parts store. You will have to disconnect the parking brake spring at the bottom to allow the shoes to spread out and rotate the axle to a point where you slide the old stud out and new one in. Then you can use some stacked washers and 7/16-20 nut to pull the new stud in place. I use a drop of Loctite on the knurl when I install new studs but I am also doing it with the axle out and in a press.
Old Oct 5, 2019 | 09:12 PM
WARVETT's Avatar
WARVETT
Old Oct 5, 2019 | 09:40 PM
Haggisbash's Avatar
Haggisbash
Hi Warvett, be very careful some replacement studs have heads on them that are slightly thicker than the originals, if they are too thick they can catch on the parking brake springs and make a real mess ask me how I know
Old Oct 6, 2019 | 07:08 AM
derekderek's Avatar
derekderek
if stud base is too big, you can chuck it in a half inch drill and fire up the bench grinder and trim thickness and width of the base to match orig. just do not heat the stud too much by grinding too fast. bubbalathe... with any new wheel stud, make sure lug nut spins on freely. if thread is tight, the knurl will spin until you get tension on it. and there ain't much to grip to hold it still.
Old Oct 6, 2019 | 08:59 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
My concern would be WHY the stud is loose. Did the splines on the stud get "worn down" by someone who was "overzealous" with an impact wrench, or did the hole in the spindle also get damaged, and is now "oversized"? If the stud is bad, which is what SHOULD be the case, as the stud is usually a softer metal that the spindle, then you can press in a new stud, without too much trouble, as stated in an above post. If the hole in the spindle has somehow gone "oversized, that could be a major headache.....
Old Oct 6, 2019 | 05:58 PM
WARVETT's Avatar
WARVETT
It was only a little loose. You can move it about an 1/8 inch up and down. It doesn’t move in or out so it seems that the bold head is still in there - just not solid like the others.
Old Oct 7, 2019 | 01:18 AM
JETS C3-C4's Avatar
JETS C3-C4
Possibly a prior owner or a shop broke the stud and replaced it with an incorrect sized one. You need to investigate some more and figure out why it is loose.
Good luck, hope you get it sorted out.
Old Oct 7, 2019 | 08:38 AM
bashcraft's Avatar
bashcraft
That's like saying " my wheel only fell off a little bit".
Old Oct 7, 2019 | 08:45 AM
bashcraft's Avatar
bashcraft
The studs aren't in the spindle, they're in the hub which are either cast or forged. Either way the stud will be harder than the hub.
Old Oct 7, 2019 | 11:49 AM
GTR1999's Avatar
GTR1999
The studs are in the spindle flange, all the same part.
Old Oct 7, 2019 | 11:53 AM
derekderek's Avatar
derekderek
Worst case scenario is you put on the tire and everything holds tight. Then you need to change the tire and the stud spins instead of letting you unbolt it. Then you're stuck with a tire you can't get off.
Old Oct 7, 2019 | 12:12 PM
bashcraft's Avatar
bashcraft
My mistake, I was thinking it was a front wheel.
Old Oct 7, 2019 | 03:15 PM
WARVETT's Avatar
WARVETT
Thanks Everyone, I will look into is soon. I'm currently working on replacing the radiator so it will wait until that is done.
Old Oct 7, 2019 | 05:17 PM
jackson's Avatar
jackson
OP WV
You got Expert advice in post #2
and as bashcraft succinctly put it ... 1/8" is too much
Old Oct 7, 2019 | 05:28 PM
leadfoot4's Avatar
leadfoot4
Bingo!!
(and it would REALLY suck if you had to change that wheel/tire "on the road", due to a flat tire....)
Old Oct 7, 2019 | 05:39 PM
Big2Bird's Avatar
Big2Bird
Bingo!!
Which reminds me. I do not recall the last flat tire I had. Maybe in the 70's?
Old Oct 8, 2019 | 07:58 AM
leadfoot4's Avatar
leadfoot4
EVERYBODY says that, but it only takes one time, to make your day miserable...….
And on that note, I've had 3 flats to deal with, since I started driving, in 1968. Two were punctures due to road debris that I wasn't able to avoid, and one was when some SOB let the air of of one of my tires, while my car was parked in a theater parking lot.
Old Oct 9, 2019 | 09:38 PM
TCracingCA's Avatar
TCracingCA
Ya! just throw it aggressively around a few turns to ensure you aren't going to kill a passenger, before you offer anyone a ride!
To Loose wheel stud
