Half Shaft Question
Old Oct 9, 2019 | 10:38 AM
lsintampa's Avatar
lsintampa
Default Half Shaft Question
75 coupe.... just had my trailing arms, half shafts, etc. rebuilt (Van Steel).
Question about torque for half shafts. The assembly manual shows 60-90 FT/LBS for where the shaft mounts to the wheel, and then it shows 25-36 FT/LBS for shaft to differential mount.
So is that correct? Seems odd to me that they would be so far off. Additionally with the french locks on the wheel side, it is unlikely they'd come free, but on the diff side, it's just lock washer and torque, which IMHO, seems low.
BTW - some PO used loctite (or something similar on the shaft / diff bolts (or so it seemed to me).
Any thoughts?
Old Oct 9, 2019 | 02:54 PM
ddawson's Avatar
ddawson
Can't comment of the torque specs but I tried the french locks and they twisted up. Used a flat washer and lock washer with red Loctite. It not going to come loose.
Old Oct 9, 2019 | 03:06 PM
Tampa Jerry's Avatar
Tampa Jerry
It may be that the outer bolts are subject to much more vibration then the inside connections. You can prevent the french locks from twisting up by putting a little grease on them where the bolts go through. Jerry
Old Oct 9, 2019 | 03:20 PM
lsintampa's Avatar
lsintampa
Yeah, I think the specs I posted are correct. I still don't understand it, but after some more digging, it seems to be correct. As to the french locks, a trick I heard was to lube them up with some grease so they tend to not twist when you torque them down. Not sure if that will work or not, but we'll see.
Old Oct 9, 2019 | 04:13 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
Specs should be right. The big difference from outer to inner is bolt size. The outer bolts can handle more torque. The inner ones on a high performance models have caps, while the lower performance ones use u-bolts.
To Half Shaft Question
