TCS Switch, Muncie Trans Mounted
Old Oct 10, 2019 | 03:13 PM
sunflower 1972's Avatar
sunflower 1972
Default TCS Switch, Muncie Trans Mounted
It's leaking. I already eliminated it on the engine side. Anybody know the thread size so I can replace with it a pipe plug from the local hardware store?
Old Oct 10, 2019 | 03:45 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
I think it is 1/2. I would suspect the shifter end is leaking before that switch though being its all nasty with oil.
Old Oct 10, 2019 | 03:58 PM
sunflower 1972
Perhaps little at the shifter, but most of the oil leak is from the TCS switch. That's why I would like to replace it ASAP.
Old Oct 10, 2019 | 04:31 PM
lars's Avatar
lars
I don't think it's a pipe thread - pretty sure it's straight thread and that the fitting seats/seals/bottoms out on a sealing surface to assure that the fitting is installed at a consistent and pre-set depth so the switch operates correctly inside the tranny. I could be wrong, but you better check it and verify before you screw up the threads in the tranny with a pipe plug.
Lars
Old Oct 10, 2019 | 05:36 PM
Sigforty's Avatar
Sigforty
Lars
Lars is right. A little more research on my part shows it is 9/16-18 straight thread. Check this out to plug the hole. https://5speeds.com/cart/index.php?r...product_id=192
Old Oct 10, 2019 | 05:40 PM
sunflower 1972
Lars
You're right. I found a photo of it. Thank you.
Old Oct 10, 2019 | 05:42 PM
sunflower 1972
Thank you Sigforty for the link.
Old Oct 11, 2019 | 04:04 PM
sunflower 1972
Dorman part number 090-030. Came with the gasket.
Installed.
To TCS Switch, Muncie Trans Mounted
