Fan Clutch Failure?
Old Oct 12, 2019 | 10:44 AM
eddp's Avatar
eddp
Default Fan Clutch Failure?
Something that I never thought about. How do you know when your fan clutch is going bad? How do you test it to see if it's working properly?
Old Oct 12, 2019 | 11:51 AM
PeteZO6's Avatar
PeteZO6
Tongue in cheek, but true.
You could try driving in stop and go traffic on a freeway for half an hour on a warm day. If the car doesn’t overheat, your fan clutch is good. Mine overheated in circumstances like that so I replaced the fan clutch with a GM clutch and my overheating problems want away.
Old Oct 12, 2019 | 02:11 PM
PJO's Avatar
PJO
Veteran: Marine Corps
One method is to use a heat gun or hair drier. Check the resistance of the fan to rotate when engine is cold then. Heat the coil spring or bimetallic bar on the front of the clutch. Resistance should be significantly higher when heated.
Old Oct 12, 2019 | 04:27 PM
MelWff's Avatar
MelWff
if you notice fluid leaking out of the hub, replace it.
Old Oct 12, 2019 | 04:45 PM
7T1vette's Avatar
7T1vette
Run the car long enough for the engine to heat so fan will be engaged (slow speed, A/C ON, etc.). Pull over (leave engine running), lift hood and while watching the fan rotation, turn ignition OFF. If the fan stops rotating after 2-3 rotations, the thermo unit is working just fine. If it slowly coasts to a standstill, it didn't get hot enough or the thermo fan isn't working.
Old Oct 13, 2019 | 10:16 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
or once its good an hot, shut off the engine and give the fan a twist with your hand, it should be tight when its hot and spin real easy when its cold.
Old Oct 13, 2019 | 01:48 PM
jackson's Avatar
jackson
FAQ fan clutch from a respected manufacturer
https://www.haydenauto.com/en/techni...q-fan-clutches
Old Oct 19, 2019 | 05:41 PM
firstgenaddict's Avatar
firstgenaddict
KIRKCONNELCORVETTES who rebuilds the Schweizer fan clutches says... with the hood up and engine at temperature - cut the engine off, if the fan continues to spin more than a turn it needs rebuilding, if it wobbles it needs to be rebuilt.
The charge was $250 turned around in 10 days. .
Old Oct 19, 2019 | 05:44 PM
7T1vette's Avatar
7T1vette
In my experience, even a NEW thermo clutch will turn more than once when the engine is shut down. Sounds like a "rule" to get more business....
To Fan Clutch Failure?
