81c3 454 engine swap
first time post and first time vette owner
I purchased a 81 vette that I’m going to restore but not OEM , I’m going to make it my vette
I want to install a bbc instead of the 350
I know it can be done but I was wondering about the A/C and heat coil box on the fire wall
Will the passenger side head hit the box
What or how to get around this without removing the A/C all together
Any info will be a help
thanks
love this forum lot of info
There is very little room between the valve covers on both sides and the power brake booster and a/c box.
I found several options for valve covers and running roller rockers, so it can and has been done.
if you do run into clearance issues, you can convert over the a vintage a/c system that eliminates the a/c box and run a smaller brake booster or switch over to hydra boost for power brakes.
