Rear Toe Alignment
Old Oct 15, 2019 | 10:41 AM
lsintampa's Avatar
lsintampa
Default Rear Toe Alignment
Can you do toe alignment with the suspension hanging - if you bring the half shaft to horizontal?
OR, do you need to do it with wheels on the ground?
OR????
I don't want it perfect, just good enuf to get car to someone to do all four wheels.
Old Oct 15, 2019 | 11:46 AM
Duke94's Avatar
Duke94
If you put the original shims back where they were, you should be close enough to get to a shop.
Old Oct 15, 2019 | 12:44 PM
lars's Avatar
lars
Originally Posted by lsintampa
Can you do toe alignment with the suspension hanging - if you bring the half shaft to horizontal? OR, do you need to do it with wheels on the ground?
Both wheels need to be compressed to their normal ride height in order to measure and set toe with any reasonable accuracy.
Lars
Old Oct 15, 2019 | 12:50 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
My PO had mine toed all the way in when I bought it.When I measured it it was toed in an inch and a quarter I think. It drove but would jump about , what felt like a foot, to the right when i hit a bump. You'll make it to the alignment shop if you get it generally close.
To Rear Toe Alignment
