Where to start from
Old Oct 16, 2019 | 11:35 AM
Steve Kistler's Avatar
Steve Kistler
Default Where to start from
This is how the car came and I was told that it did run before the engine went bad. Is there a simple way to clean up this wiring mess? Thanks
Old Oct 16, 2019 | 11:46 AM
bashcraft's Avatar
bashcraft
You can't "clean up" melted wires and plugs.
Old Oct 16, 2019 | 12:06 PM
Steve Kistler
Understandable which was the reason for the post. Where to start from. Not looking for a discussion,just some helpful information Thanks
Old Oct 16, 2019 | 12:08 PM
carriljc's Avatar
carriljc
First thing you want to do is find a good wiring diagram. If you're comfortable working with wiring then it's relatively simple....if you're not, then it might be a bit frustrating.....anyway;
Identify the damaged connectors and order some replacements. Meanwhile go get some heat shrink in various sizes and a small soldering torch and some fine solder. You can probable find that all at Harbor Freight for a pretty good price. Start cleaning your wires and sorting them out. Find a wiring diagram and determine what is what. Once you have it sorted out, then do some system checks before soldering things together.
I
Old Oct 16, 2019 | 12:19 PM
ignatz's Avatar
ignatz
The first thing is to disconnect the battery. Doc Rebuild has some really good wiring diagrams although you haven't said what year your car is. If you are not interested in originality, Weather Pack has some really good electrical connectors and I've gotten mine from Pegasus Racing. They do require the correct tools to crimp, etc.
As Carriljc says, heat shrink and a decent size soldering gun/iron. Clear heat shrink allows you to slide in a piece of paper identifying the wire. Print it out on your computer in 9 point type. Oh and get some quality wire strippers.
Old Oct 16, 2019 | 12:29 PM
Steve Kistler
This is the sort of information I was seeking. Thanks to you and Carrilljc I have some place to start. Appreciate it.
Old Oct 16, 2019 | 12:30 PM
carriljc's Avatar
carriljc
You're welcome. Don't forget the quality wire strippers mentioned by ignatz
Old Oct 16, 2019 | 02:09 PM
1fastC3's Avatar
1fastC3
Like others have said, check out Doc Rebuild, excellent wiring diagrams! Also at this point you'd probably be better off buying a new wiring harness, I've had good luck with lectric limiteds wiring harness'
Old Oct 16, 2019 | 06:10 PM
stevedinino's Avatar
stevedinino
x2 on the Doc Rebuild wiring diagrams. I bought his diagram for my 77 after spending money on one from another vendor that was flat out wrong. Pretty easy to decipher and covers mid year changes too (at least for my year).
Word of warning tho: brown wires on the diagram turn purple after a while in the sun! Makes it really hard to understand at a glance. Very frustrating, but totally my own fault.
To Where to start from
