69 Headlight Doors
Old Oct 28, 2019 | 05:07 PM
sjstub's Avatar
sjstub
Life Member
Default 69 Headlight Doors
Having a hard time getting enough vacuum to either raise or lower both headlight doors. I can do 1 door at a time after disconnecting 1. What are the possibilities for the weak link in the system? All new hoses, checked & rechecked for proper connection. Oiled all points on the hdlt ***'y. Replaced check valve, filter, hdlt swx... Any ideas out there?
Old Oct 28, 2019 | 06:09 PM
Peterbuilt's Avatar
Peterbuilt
Many times the 'grommet' seal in the actuator needs to be replaced.
Here's a good 'How-to' to help you check each component.
http://www.corvette-101.com/vacuum.htm
Old Oct 29, 2019 | 02:12 PM
kodpkd's Avatar
kodpkd
There is a great DIY on YOUTUBE, how to rebuild the actuator.
Old Oct 29, 2019 | 03:17 PM
L-46man's Avatar
L-46man
Just going to the fundamentals here....what vacuum are you getting at the manifold port at 750 RPM??????
Old Oct 29, 2019 | 09:11 PM
sjstub's Avatar
sjstub
Life Member
Thanks...I'll take a look at it.
Old Oct 29, 2019 | 09:12 PM
sjstub's Avatar
sjstub
Life Member
8 at best. Usually 5-6. Running a Hi-performance Comp Cam
Old Oct 29, 2019 | 11:18 PM
Joelbbvette's Avatar
Joelbbvette
I had slow action on my 72, checked the seals on the 2 head light actuators and the wiper door. After ruling those out, I needed to replace the controllers. That solved my issues and from super slow they now slam up and down. That is with all original hoses. So food for thought. One step at a time and start with the cheap parts and a brake vacuum pump really helps.
Good Luck
Joel
Old Oct 29, 2019 | 11:24 PM
forman's Avatar
forman
check out corvette 101.com
Old Oct 30, 2019 | 06:56 AM
sjstub's Avatar
sjstub
Life Member
Not looking to buy one...
Old Oct 30, 2019 | 09:09 AM
Gabriel Vianna's Avatar
Gabriel Vianna
Is there a guide like the one on corvette 101 but for the wiper door?
Old Oct 30, 2019 | 10:08 AM
sjstub's Avatar
sjstub
Life Member
This troubleshooting guide will work for the wiper doors for the override switch and the relay valve...same same, different functions.
To 69 Headlight Doors
