Global West Rear Trailing Arms
Old Oct 29, 2019 | 04:56 PM
domar5457's Avatar
domar5457
5th Gear
Default Global West Rear Trailing Arms
Looking for possible reviews of Global West rear swing arms with front pivot bearing for 1980 C3. Anyone have any thoughts good/not so good? Are they worth the extra money vs. front rubber/poly bushing? Getting ready to tear down and rebuild rear suspension and not sure which way to go for the control arms.
Old Oct 29, 2019 | 07:07 PM
ignatz's Avatar
ignatz
I had an early production set with the spherical bearing. The emergency brake cutouts were wrong and I had to hog out a hole and complained about it. I also had to shorten the emergency brake cable. That was actually my first post on this forum if you can find it. Others commented there too so that thread should be helpful to you.
GW soon fixed that problem in production and even offered me another set but by that time they were already on my car. There were some other minor fitment issues. I didn't weigh them but suspect they are considerably heavier that the stock arms. They seem very robust and I've had no complaint since.
Here: https://www.corvetteforum.com/forums...ficulty-2.html
And here: https://www.corvetteforum.com/forums...ling-arms.html
There's more from others
Old Oct 30, 2019 | 12:55 PM
domar5457's Avatar
domar5457
5th Gear
Thanks for your quick reply, I appreciate the insight. Looks like there could be some minor tweeking if I go this route.
Old Oct 30, 2019 | 07:16 PM
GTR1999's Avatar
GTR1999
I have setup these TA in the past, had the same issue as above and also the studs used with them are not the knurled type like GM used. The holes in the caliper bracket have to be drilled open. I haven't built a set in a few years so I don't know if they resolved these things. They are a nice strong arm but we have drag raced with stock arms without a problem as long as they were not rotted or bent.
Old Oct 31, 2019 | 10:37 AM
domar5457's Avatar
domar5457
5th Gear
Thanks for your reply. I appreciate the insight I am getting concerning these TA's from everyone. Not sure what studs you are talking about? My understanding is the TA's come with new bolts for the bearing/spindle assemblies. Still learning about these, but isn't the caliper bracket and studs (are you meaning wheel studs) part of the bearing/spindle assembly? The TA's from Global I am looking into are just the bare TA's without bearing/spindle assemblies.
Thanks...………...Don
Old Oct 31, 2019 | 04:15 PM
GTR1999's Avatar
GTR1999
Don,
You need studs to hold the support and bracket to the arm. GM used 3/8-24 knurled studs and they work great. The studs that came with the GW arms were plain grade 8 hex bolts, I think they were 7/16 so the holes in the support were not large enough. There is no issue drilling them out but I personally like the GM setup better. Our car was just about ready to break into the very high 10's and still had new stock arms without a problem. When we sheared off both the LH inner and outer Solid Spicers joints the shaft destroyed the drag vette loop and bent the arm. I went to Tom's offsets and 1480 12 bolt to resolve the issue.
Old Oct 31, 2019 | 04:23 PM
ignatz's Avatar
ignatz
Don,
This sounds very familiar. Dave Herlinger (now retired), Corvette Repair in Mt View put my arms together and I remember he had similar complaints about that part of the GW design. I also have Tom's axles which he installed. Maybe I'll look up his invoice next time I'm in that pile of paper.
Old Oct 31, 2019 | 05:23 PM
domar5457's Avatar
domar5457
5th Gear
Don,
I think I may stay with the GM arms (you've changed my mind). I'm not looking necessarily for drag strip or road race strength arms and parts although I am planning on engine upgrade to around 400HP so I want my rear suspension rebuild to be able to handle that amount of HP.
I do have a question for you since you seem very knowledgeable concerning the rear suspension. When looking at parts for the rear suspension I notice a lot of times they want to know if you have Auto or Man Trans (I do have a 350 Turbo currently). Does it really matter once you get to the differential whether you have an Auto or Manual trans?. Are Manual Trans parts possibly more heavy duty than Auto trans? Will the OE 1/2 shafts and U-Joints hold up to the HP OK?
I do appreciate your time
Old Oct 31, 2019 | 05:26 PM
domar5457's Avatar
domar5457
5th Gear
Thanks again for your help
Old Oct 31, 2019 | 09:19 PM
Big2Bird's Avatar
Big2Bird
Originally Posted by ignatz
............ I didn't weigh them but suspect they are considerably heavier that the stock arms. They seem very robust and I've had no complaint since.
I lost interest here. Heavier is out for me. Looks like stock with Johnny Joints for me.
Old Oct 31, 2019 | 09:29 PM
ignatz's Avatar
ignatz
I'll leave you both with one thought, plenty of room for wider wheels and tires. I could easily go to 10"s.
To Global West Rear Trailing Arms
