Need starter recommendation BBC
Car: 496 big block, 10:1 compression. XFI. Been using an Autozone Duralast Gold DLG9990S starter. This is basically the late 90's GM gear driven starter. Lasted forever on the 350 but seems to be only good for ~6 months on the big block.
Symptoms: Starter will engage and start cranking and then it seems like the pinion disengages from the flywheel. Sometimes it re-engages, sometimes not. Last time this happened, a mechanic suggested shimming the starter closer to the flywheel. That resulted in about 20 destroyed teeth and me having to pull the T-56 to get the ring gear replaced.
- Timing is set at 15 BTDC when cranking in the EFI timing map.
- Confirmed that the ring gear is not slipping on the flywheel. Had a sharpie mark on the ring gear/flywheel from install and no movement evident.
- Inspected every single tooth, turning engine over by hand. All 168 look good. No chips or wear.
I did have a Powermaster XS Torque starter sitting in the garage that I was going to install till I noticed how loose the bolts were in it. Lots of play. And then I noticed the cracked case. Calling Powermaster on Monday. Please don't recommend one.
I have heard good things about CVR. Thoughts?
Honestly, I just one to do the job once. I have a Cars and Coffee next Saturday so got a little time but plan is order something this weekend if able.
Cracked Powermaster:
The DB Electric is another version of the stock GM starter. The Duralast should have worked, unless that version is simply a piece of crap compared to the other brands..DB Electric products seem to work very well, and have great prices too.
Bit the bullet and ordered a Tilton. I am going to call Powermaster tomorrow about the cracked one.
1976 CHEVROLET CORVETTE Summit Racing® Protorque Starters SUM-820323-OS
A paper clip is about .050-.060 and is pretty close.
Very old school trick.
I believe that your previous starter was too close.
Jebby
