Convertable Hinge Bracket Picture
Old Nov 2, 2019 | 09:07 PM
Gale Banks 80''s Avatar
Gale Banks 80'
Default Convertable Hinge Bracket Picture
A previous owner removed the Spring Hinge assembly for the rear Deck. I have got some replacements but I'm still missing something. There must be a Steel Bracket that is riveted into the well above the body mount. I don't have mine. The donar car must of been badly rusted cause about all I got was a little bit of sheet metal and a square nut . This is not a part that would be normaly removed I'm sure it was Riveted into the Birdgage.There is an odd piece of exturded Aluminum that is used for a spacer between the missing part and the Spring Tower. Anybody have a picture of what it looks like ? I'm sure I can make one, if only I knew what it looks like.
Old Nov 3, 2019 | 10:04 PM
caskiguy's Avatar
caskiguy
What year is the car ?
Old Nov 3, 2019 | 11:17 PM
Gale Banks 80'
Its a 1969. I doubt there was any change from 1968 to 1975.
Old Nov 4, 2019 | 11:44 PM
Gale Banks 80'
Well it turns out reproductions are available. And yes there is a 68-70 and a 71-74 versions made so there was a change in the run.
To Convertable Hinge Bracket Picture
