Oil in Intake Runners
Should you be concerned? IDK. Maybe not all AFRs are like that. But before I would start removing 16 rockers and studs, I would buy a dental mirror and take a peak inside the runners of one head anyway. If you see any rockerarm stud threads in the runner, then you know what you need to do.
You would think that AFR was aware of this issue and already sealed the rocker stud threads. Who knows?
Time and gaskets are all you lose here....
Trust but verify....40 posts speculating what the issue may or may not be is not doing anything.
Jebby
Jebby
Jebby
For the record, I don't think you are set at 45 degrees BTC. If I get my stock 350 at much more than15 BTC it tries to rip the teeth off the flex plate when I try to start it. I don't think you cam timing is off either, Back in the day the 350 came with nylon tooth cam gears which wore quickly. I jumped one tooth and could barely get it home. If you are at 45 degrees BTC, the piston is about 1" down in the cylinder and I don't think any of the TDC tools will hit the top of the piston. As for the timing damper outer ring moving, it would have to move 2" circumferentially to be off 35 degrees. I never had one of these fail, but I would suspect if it did move this much, it would keep moving as I tried to time it and the timing would at best be inconsistent, the damper would likely wobble or worse you would find 2 pieces; one connected to the crank and the other on the road.
I think you either have a problem with your timing light or you have the wrong damper or indicator on the timing chain cover is off. .
Good luck
It is why everything I work on gets a billet tab with pointer and corresponding balancer...
In over 25 years I have seen people chase their tail and spend thousands tracking down problems that don’t exist due to timing.
The OP’s engine may run fine but the fact is that it is probably no where near optimal timing for the engine because it is impossible to tell.
Once you know....you know....before that, everything else is speculation.
And you gain tremendous piece of mind knowing.....
Jebby
Good luck
it certainly could be the timing light, so I need to find or buy another one. As for the damper or indicator, I already checked this but could be wrong. I will try to verify......again. Once I can get a TDC determined I will methodically go from there as there has to be something simple wrong.
Apparently the common piston TDC tool that screws in to the plug hole does not work on AFR heads due to angle. I am pulling the head and doing it that way.
If you are going to pull the head, you should do the compression test first, so you know if you have a problem there that may be related to your oil issue.
I then did a differential check on cylinder #1 and it indicated a 4% loss at 100 psi. I did not check any other cylinders given they were all consistent with the cranking check. I would expect all cylinders would leakdown close to the 4%. This was down with my new Longacre leakdown tester.
So, interested in your input. Seems to me, my cylinder compression is as good as it gets.
To recap....you need to look at exposed rocker studs in the intake port, wiped out valve seals, and intake face sealing....these three things are the only way to get oil in the ports. I believe the oil in the intake is simply reversion.
Jebby
I pulled the balancer and attached the timing wheel to crank with the barrel attach nut in the kit. I measured lift off the intake lifter. I checked the cam timing, using both with the intake centerline method that Comp recommends, and the traditional way checking at 0.006 lift and at 0.050, and comparing to the cam card numbers. I also posted picture of my card.
Here is what I found, checked it three times to make sure no mistakes. The intake centerline, according to the card should be at 106 degrees. Its actually at 110 degrees, four degrees retarded. And the dots are perfectly lined up. When checking the intake opening point at 0.006 lift, the cam card says it should be 29 degree BTDC. Its at 25 degrees BTDC, which I believe confirms the cam is installed FOUR degrees retarded. I also calculated what the lift should be at 0.050 lift, and it also confirms the four degree difference. Please back me up on my numbers, but I believe I am correct. The total lobe lift is only showing about 0.327, when the cam card says it should be .330. So, it looks like the cam was not ground per specification, if I am correct.
So for four years, I have driven this car, thinking it was a big disappointment from what it should have been, and now maybe we know why. I thought I degreed the cam when I installed it, but I may have just stuck it in and lined up the dots. I really do not remember.
As for the ignition timing running at 40 degrees advanced at 800 RPM, with vacuum disconnected, the TDC check today confirms the balancer has not slipped, but since the timing pointer was ten degrees off, it was really running at 30 degrees advanced, which is still way too much. So either I have a timing light issue, OR this four degree cam timing difference is somehow affecting it the engine in a way that requires more advance to run?? Is that possible?.
So, if I get this cam timing corrected, which is going to require an adjustable timing gear setup..….will my engine substantially different, and how much? I don't know if Comp Cams will do anything about this being so far off, after four plus years.
Honestly, my mind is frazzled with all this, so if I am interpreting any of this wrong, please let me know.
They usually are:
Zero, 4* retarded, 4* advanced via symbols.
My last Cloyes set of instructions must have been dropped in a mud puddle. The drawing and symbols were a blurry mess. Triangle, square, circle, but I figured it out.
And years ago they had offset keys just to mess people up. And make sure the cam sprocket does not have an old offset dowel bushing. E-gads. The things people used to do.
They usually are:
If you find that the bottom gear is in fact in the correct position....buy a Cloyes Hex-a-Just and degree it out....4 degrees is not going to cause distributor timing to be way off to run....
Jebby
At 16,000 miles, I would say some slight timing chain stretch would be worth maybe one degree retarded from specs. As for the cam lift missing three thousandths, I suppose some oil w/o zinc could be its demise or normal wear. But that's really close. I bet a tear-down of any engine with 16K would show 0.02 - 0.03 wear on lifters or lobes. Miniscule.
Most performance cams from the factory come with 4* advance built in. It gives the brand new cam owner a satisfactory low-end grunt.
Your cam is reporting 4* retarded. You would have very little grunt off idle. But scream above 5,000. That's kind of what you said from the begining.
I think you should run your test two more times looking for exact matches as before. Then shine a good light on the crank sprocket. See if you can make out a symbol or number near the keyway and look for additional keyways.
Then set it "straight-up", zero mark. Run your test again. Not satisfied with specs matching cam card? Set it up at 4* advanced. Run your test again.
Once the cam is phased where it belongs, I think it will feel like you added 100 horse. Advancing the cam that many degrees will move the power band to around 2,000-5500. This is more streetable and torquey. Keep this engine.
- Get your cam degreed in correctly. You are almost done with that. 4 degrees retarded is a lot.
- Fix the pointer to read TDC when the piston and balancer is at TDC. You can't correctly set timing without it. You don't know how retarded your total timing might be, and even 4 degrees off is a lot and will only add to its already weak output.
- Set your inital timing to somewhere around 12-15 (with no vacuum advance) and then set the total advance to exactly 36 degrees. This should occur around 3500 rpm depending on you distributor set-up. You must make sure it does not advance any more than that at higher rpm.
- Looks like you have a degreed balancer. If not add a timing tape or just a mark at 36 degrees. I would set your timing without using the dial back feature on the timing light. They are known to fail.
There is always the option of going one step smaller on the cam, that one should pull strong from 1200.
But get the timing correct first.
