Oil in Intake Runners
Took the intake manifold off and found ALL cylinder intake runners full of coked up oil residue, valve stems caked up, and all runners wet with oil. See pictures. I used Felpro 1256 gaskets, with no goop on the intake ports, i.e. no RTV, etc. Felpro says to install dry. But it appears maybe I am sucking oil on all cylinders, because I see no reason why there is this much oil on the intake valves and both heads and Performer RPM intake shows black oil residue. If my rings were shot, which makes no sense, would I not be burning oil? No smoking, no oil consumption. I am getting 18 inches of vacuum at idle., so I did not think I had vacuum leak, but? I have less than 16000 miles on this engine. My question:
Why does it measure 40-45 degrees advance at idle with the distributor installed correctly? Some say it is impossible. And I drove it three years without any pinging under load, till late this year, And it was very minor. NOT using oil at all and 18 inches of manifold vacuum??
- GM ZZ4 factory hydraulic roller short block
- AFR 180cc Heads, 65cc Chamber 10:1 Compression (015 gasket)
- GM Factory Hydraulic Roller Lifter system
- Comp Cam Extreme Energy XR270 Roller Cam (218/224, .500 lift, 110 LSA)
- Comp Cam Ultra Pro Magnum Steel Roller Rockers
- Edelbrock Quadrajet RPM intake
- Quadrajet rebuilt by Lars (with the above engine specs)
- DUI Performance HEI Distributor
that’s a lot of oil. How is the clearance on you valve guides. Take off a spring an intake valve and check it, along with the guide seals as well.
i use rtv ( ultra black permatex or similar) on the intake gaskets despite what Felpro says, they are not the ones who’ll have to take it apart and do it again if they do leak.
https://www.summitracing.com/parts/cca-4795/overview/
Rotate crank to close to before TDC. Screw in the tool until it hits the top of the piston. Rotate the crank back and forth until you find the spot where the tool hits the piston about halfway in. Mark that on the tool with paint. Make a mark on the balancer as well. Rotate engine past TDC and find the spot where the tool hits the piston as it is going down at the same tool adjustment. Make a second mark on the balancer. True TDC is in between your marks.
And then there are the people that say: "I never put any sealer on my gaskets". Well, here is a classic example why you should. Either Edelbrocks Gastiniche or Permatex Black or Permatex The Right Stuff on BOTH SIDES of the gasket.
You were sucking oil vapor out of the lifter valley. Order best new gasket, best sealer money can buy, and start scraping that old crap out of there.
Yes....verify TDC #1 with the tool.......report your findings here.
Make SURE the vacuum advance is unplugged to check timing......leaving it connected can fudge the numbers at the light by up to 20 degrees.
Jebby
I disconnected the vacuum line from distributor when checking timing and plugged it. No difference.....still indicates 40-50 advanced at idle.
As for the oil in the intakes, I will check the angles and china wall gap, but there it is definitely not bottoming out. I also want to point out that I have oil well up into the intake manifold,.and on the bottom of the floor under the carb....so I am not convinced its an intake gasket leak....would there be oil in in the floor and intake runners of the intake manifold with this leak?
What are the chances I would have oil leaking past the rings, pressurizing the case and the PVC system sucking oil into the carb? I cannot understand why the rings would be bypassing oil at 16000 miles. AND, I do not have any noticeable oil consumption, and no smoke out the exhaust. Which leads back to leaking intake manifold gasket.......but again....would there be oil up in the intake runners of the manifold with a leaking gasket given the flow is out of the intake and into the head?
And not sure how I am going to clean these heads.....maybe have to disassemble them to get it clean.
No need to pull the heads at this time. Just wait for more data to surface. The valve-stems can be cleaned through the ports, good enough.
If that kinda tool won't work on your heads then do it old school. Take an old spark plug and a piece of rope and knock the guts out of the plug till all you have left is the metal threaded part also cutting off the electrode. Run a piece of rope through it and tie a knot in the piece of rope with about 4 inches hanging off into the combustion chamber. This should bottom your motor out on the rope. Not as accurate as the tool above but given how much we think it's moved it will confirm it. No good reason to pull heads to ensure your balancer has or has not slipped.
In any case, I will do compression leak down check and standard compression check next and report back. I am getting ready to pull this motor and sell it anyway, I need more big block like torque so most likely building Dart SHP 406......so, motor for sale in C3 classified if interested. Selling as whole engine or might part out heads, short block, whatever. I know given the problem, I am probably hurting my sale, but whatever,.....I am an honest guy.
If you crack a piston it can puke oil up into an intake runner and then into plenum and then down into other runner(s
If you crack a cylinder wall it can puke oil-water mix up into an intake runner and then into plenum and then down into other runner(s)
This would allow oil to be sucked into the plenum from the lifter valley. Very little oil consumption will be shown on the dipstick but never the less this would show up in the plenum and cake the valve-stems.
This is an easy fix as stated in post # 5. Slap some new gaskets on there and run it!
