intake manifold gasket needs changing?
Old Nov 10, 2019 | 01:53 PM
Primoz's Avatar
Primoz
2017 C3 of Year Finalist
Default intake manifold gasket needs changing?
I noticed that on my center 2 bolts on my intake manifold I have very small accumulation of oil.
Car runs normal.
Does the intake manifold gasket needs changing? I tried to torque it down a bit but the bolts are quite snug as it is.
The car is 71 L48 with stock heads and Performer manifold and Lars quadrajet.
Also I have these Edelbrock gaskets at home for some years now. Should I use them or go Fel-pro with exhaust crossover blocked?
Also how do these rockers look to you more experienced guys?
Old Nov 10, 2019 | 02:28 PM
jackson's Avatar
jackson
if you have Permatex number 2 non-hardening sealer ? Very common in USA
If so, pull one bolt at a time and clean threads of oil ... smear some P#2 on threads and reinstall ... repeat, one-at-a-time for each center bolt.
Old Nov 10, 2019 | 02:37 PM
lars's Avatar
lars
Originally Posted by Primoz
I noticed that on my center 2 bolts on my intake manifold I have very small accumulation of oil. Does the intake manifold gasket needs changing?
Whoever installed the intake manifold failed to seal the bolt threads. You don't need a new gasket - you just need to remove the intake manifold bolts, clean them up, and put some sealant on the threads before reinstalling them.
Lars
Old Nov 10, 2019 | 02:59 PM
Primoz's Avatar
Primoz
Found the sealer! $8 in Europe!
Old Nov 10, 2019 | 03:15 PM
lars's Avatar
lars
Permatex #2 is good, but you can use any silicone gasket sealant on the threads with the same good results. Just a dab of silicone on the threads and snug the bolts back in. No problem.
Lars
Old Nov 10, 2019 | 03:20 PM
Jstan2014's Avatar
Jstan2014
Old Nov 10, 2019 | 03:27 PM
lars's Avatar
lars
Not understanding what the "popcorn" is for. I didn't argue that the Permatex #2 is not good. But if you don't have it on hand, and happen to have some silicon-based gasket sealer, you can use it with equally good results to seal non-pressurized bolt threads.
Lars
Old Nov 10, 2019 | 04:25 PM
Jstan2014's Avatar
Jstan2014
That’s just me “lurking” to learn. No offense intended. I’m here a lot trying to learn as I go. It’s actually easier (less clicks) to post the popcorn than to click to subscribe to a thread.
Old Nov 10, 2019 | 05:34 PM
Big2Bird's Avatar
Big2Bird
Lars
Movies.
No Drive In theaters in Colorado?
To intake manifold gasket needs changing?
