Dry Carburator ????
Old Nov 11, 2019 | 06:32 PM
Roy W.'s Avatar
Roy W.
Disabled by request 8 JUN 2025
Default Dry Carburator ????
'81 small block.......I have a quadrajet on my stock '81 with aluminum intake that was rebuilt by National Carburetor in Jacksonville,FL. When starting for the first time each day it takes a bit of cranking (choke closed) to start the car. After that it starts on the first spin of the starter. I pulled the air cleaner off today before initial start of the day with the engine stopped and looked down the carb throat while working the throttle and there was no accelerator pump working. My deduction was that the carb bowl was dry. After it started the accel pump worked fine and the car runs flawlessly. Engine temp every time was 180-200 degrees. Is it possible the bowl percolates dry after shut down?? My infra red temp gun showed carb bowl temp to be 130 degrees and thermostat housing to be 180 degrees .Heat soak?? Are idle passage plugs still a problem?? The carb gasket is the 1/4 inch open hole type provided by the carb rebuilder. Would using a 4 hole gasket help??......Lars HELP.
Old Nov 11, 2019 | 07:44 PM
MelWff's Avatar
MelWff
Check valve in fuel pump not working.
fuel filter in carburetor not equipped with check valve.
least likely, leaking plugs in carburetor body.
email lars at v8fastcars@msn.com
Old Nov 11, 2019 | 08:48 PM
Big2Bird's Avatar
Big2Bird
I have come to the conclusion, they just do after a few days after parking hot.
Just depends how long it sits.
If it sits a week, yes, gotta fill the bowl.
Old Nov 11, 2019 | 09:02 PM
PAmotorman's Avatar
PAmotorman
if your corvette has a fuel return line to the tank you need to use a fuel filter with a check valve to prevent the float bowl from leaking down
Old Nov 11, 2019 | 10:32 PM
ronarndt's Avatar
ronarndt
I have this problem in my 68 bb convert. When the engine is hot, turned off and left to sit for over 30-45 minutes, the hot engine boils off all the gas in the fuel bowls on my QFT double pumper. (no problem if the engine is turned off while it is still relatively cold). A thick insulator gasket/spacer under the carb helped a little, but I finally changed to an electric fuel pump. Now I turn the ignition key to the "on" position, listen for the fuel pump to run for 15-30 seconds as it re-fills the fuel bowls and then turn the key to the "start" position and the car starts instantly, instead of cranking the mechanical pump for half a minute. Note: to confirm that heat sink is boiling off the gas and not some other problem, like bad needle and seat, get the engine up to operating temperature, park it in your garage or some quiet place, turn off the engine and listen for the bubbling sound of the gas percolating. I have glass sight windows on all four corners on my carb and I can see little bubbles as the gas boils.
Old Nov 12, 2019 | 08:48 AM
PAmotorman's Avatar
PAmotorman
do you have the heat riser crossover in the intake manifold blocked and the heat riser valve wired open so the exhaust heat is not heating up the intake manifold ??
Old Nov 12, 2019 | 01:00 PM
7T1vette's Avatar
7T1vette
There are two possibilities:
1. The carb is 'dry' as you suspect:
2. The accelerator pump in the carb has a bad seal on it.
The latter item is the most likely. But here is how to test to find which one of those possibilities is really the cause. In the morning, go out to start your engine....but DO NOT depress the accelerator pedal. Just crank it so that fuel will be pumped into the carb bowl (this assumes that your carb is draining back to the fuel tank when sitting idle). Now, open the hood, remove the air cleaner, and look for getting squirts into the primaries when you pump the carb throttle.
If you get good squirts of fuel, your carb IS draining fuel back to the tank. SOLUTION: Buy a fuel filter with a back-flow prevention valve on it. A buck or two more, and that should solve your problem. P.S. Use TWO wrenches to release that fuel line nut going into the carb body!!!
If you do NOT get any squirts of fuel into the primaries, your problem is a bad seal (most likely cause, anyway) on the accelerator pump in the carb. If your seal is not of modern materials, it will swell and fall off the piston when you put ethanol-laced fuel into your tank. No seal....no squirts. You can buy just a new accelerator pump WITH an ethanol-capable seal at most GOOD auto part stores.
Old Nov 13, 2019 | 02:42 PM
Sayfoo's Avatar
Sayfoo
Same situation on my '69. If I just start the car and quickly shut it off, it will stay full of gas for weeks. So, I've concluded that it is not leaking or draining back, but boiling or evaporating. A insulating gasket probably doesn't help much because everything in the engine compartment is really hot. Modern gas probably makes this worse.
Unrelated to this, my research back in the day, concluded that a 4 hole gasket was the best for my car for performance.
Old Nov 14, 2019 | 09:18 PM
ronarndt's Avatar
ronarndt
Sayfoo- I was pulling my hair out trying to figure out what was wrong with my dry carb. On day I parked the car in the garage after driving it for about an hour and stayed in the garage working on some stuff on my work bench. I kept hearing this peculiar noise and finally tried to find what it was. I tracked it to my car and it was coming from the engine compartment. I opened the hood and this bubbling noise was coming from the carb. My QFT carb has glass sight windows on all four corners showing the fuel level in the fuel bowls. I could see little bubbles in the liquid gas and over the next hour watched the fuel level go down and down and finally there was no gas left in the carb. It still boils the gas off when the engine is hot, but my electric fuel pump re-fills the carb if I let the pump run for 30 seconds before turning the key to start.
Old Nov 15, 2019 | 01:49 PM
squared's Avatar
squared
Default "freeze" plugs
If you take the throttle plate off the carb, you will notice two freeze plugs underneath the float bowl. These frequently developed leaks, draining into the manifold. Back in the day, you used to remove those and put plugs with o'rings in there.
Sold many of those when I was selling auto parts. Probably can't find them today. Nor a real auto parts store with an auto parts salesmen.
Old Nov 15, 2019 | 03:42 PM
Roy W.'s Avatar
Roy W.
Default Success
I cured the "dry carburetor" problem by switching the fuel filter to one with a check valve (NAPA 3052)
Old Nov 15, 2019 | 05:44 PM
derekderek's Avatar
derekderek
it is not floating up out of the bowl and disappearing past the needle and seat to drain back into the tank. the mech fuel pump has 2 one-way valves to stop fuel in the line from draining back. it is either evaporating or the leaking plugs let it drain into the intake.
Old Nov 15, 2019 | 07:23 PM
MelWff's Avatar
MelWff
Those valves in the pump can leak causing fuel to siphon out of the carburetor
Old Nov 16, 2019 | 07:16 AM
derekderek's Avatar
derekderek
The needle and seat are above the fuel level and bowl is vented to atmosphere. If pump leaks down, it will fill the fuel line with air.
Old Nov 16, 2019 | 11:39 AM
Roy W.'s Avatar
Roy W.
"The most common cause of Q-Jet start problems, if it occurs after the car has been sitting overnight or longer, is that the fuel standing in the fuel line between the pump and the carb is draining back through the fuel pump checkvalve due to a slight leak in the pump's internal checkvalve. Since the Q-Jet's needle and seat is in the bottom of the float bowl, the fuel draining back through the fuel pump will actually siphon fuel out of the carb's float bowl.".....Quote from one of Lars papers.
Old Nov 16, 2019 | 11:47 AM
MelWff's Avatar
MelWff
Default Fuel siphon
Read post #10 in this thread
https://www.corvetteforum.com/forums...-to-start.html
To Dry Carburator ????
