Help. Engine stalls with braking
Old Dec 13, 2023 | 11:02 PM
Dogmark's Avatar
Dogmark
Try adjusting your idle speed screws with the engine off turn them all the way in until you feel resistance then back it off two turns hook up a vacuum gauge Start the engine and then adjust each one inward until you get the most amount of vacuum, Then check your idle speed rpm
