I'm still having stalling issues with hard braking. 1968 427 4 speed with transistor ignition, power brakes and Quick Fuel 850 carb. Here is what I've tried to identify the problem so far: 1. Adjusted float bowls, lowered to just below the sight glasses. Still stalls. Ran a plastic tube between the bowl vents. Still stalls. Switched to my old Holley 750. Still stalls. 2.Disconnected and plugged the vacuum line to the tank. Still stalls. I must be going ten mph or more and hard brake for it to stall. If I just hit the brake pedal hard while not moving nothing happens, no blips or hiccups. 3. New transitor ignition harness, new engine harness. I even hot wired from the horn relay terminal to the ignition wire and it still stalls. 4. I've checked the battery ground and the engine block ground. They seem to be good. I ran a jumper wire from the TI box to the frame. It still stalls. None of the accessories, radio, lights cut out while braking.
I turned up the idle to 1500 rpm so now the engine just nearly dies under braking. At 1000rpm or less it will die.
I'm all out of ideas and have been struggling with this for a year. Does anyone have any suggestions?
Fuel pressure is fine. I have a new Holley pump as a result of this process. I was getting low pressure as the engine warmed up but that was due to the gage mis reading with heat. Once the plug on gage was removed, the pressure went to normal. Another case of chasing my tail when nothing was really wrong.
I am running a vacuum advance. I set it at 6 BTDC with the vacuum advance plugged. It ran at idle in this condition. But it could have moved. I can plug it off and run pure mechanical and see if this eliminates the problem.
I was not intending to imply removing vacuum advance would solve the problem. I was trying to get you to run manifold vacuum to get extra timing at closed throttle.
So what is the pressure with the Holley pump, too much can also be a problem.
Did you originally have a return line and you disconnected it?
Why do you have initial timing set to such a low number?
What make and model number distributor?
You should be 10 or 12 with out vac advance , with it connected add what ever that vac pod provides 10 or whatever its rated for. Also check a few plugs make sure you are not running rich that at idle , That will extinguish the flame like you are describing . Also make sure you have NO vac leaks .. That will also cause this issue
Your timing is WAY off - it's really grossly retarded. Before you go chasing other problems, fix your timing. On that engine, you need to be running initial timing (with vacuum advance disconnected) in the mid- to high-teens (16 - 18 degrees). Verify your total timing is in the 38 degree range and fix your centrifugal advance curve if needed to achieve 38 total with initial in the high teen range. Then run a vacuum advance control unit limited to about 12 degrees, hooked up to manifold vacuum, thus giving you actual timing at idle of about 30 degrees. Once you have the timing fixed, see if the car still has a stalling problem...
I'm running manifold vacuum to the original TI distributor (k66).
The fuel pressure was 7 or 8 psi at idle. It was exactly what it should have been.
The carb could be running rich. It is something I can check.
TT
But you put two carbs on it.
Do as Lars suggested and advance the timing.......this is important. Disregard the engine sticker under the hood and the Shop Manual....those timing numbers were created by lawyers in the 60's......
The only other thing I can think of is that the rockers may be too tight.......I ran into this on an offshore boat with a BBC....it would stall when you got out of it after running sustained RPM.....
We loosened the rockers one half turn and it stopped........what was happening was the engine would stop so fast the lifters would not bleed down fast enough and would hold valves open.
Jebby
I think the timing posts are headed the right direction. You can also test by breaking hard in gear and out out of gear (coast let engine get to idle, then brake).
The 'sock' that pre-filters the fuel COULD BE 3" from the bottom of the tank. Can you correlate the stalling issue to a 'low' tank.? Fuel pressure would not reflect braking uncovering the fuel sock.
I'll adjust the timing this weekend. I thought starting with 16 would put you way over the 38-42 degree max with the vac advance attached.
Does anyone know how many degrees you get from the mechanical advance and the vacuum advance from a stock 1968 390 hp transitor ignition distributor? Does the vacuum advance back down at high rpm?
Thanks,
TT
Advance is checked with the vacuum advance unplugged.
Vacuum advance only works when the throttle blades are closed or almost closed....like at idle or part throttle cruising.
Set the total for 38 total at 3000 rpm. Tighten the distributor. Plug vacuum back in and go for a ride.....post your results.
You said you have hard braking and You said it does not stall at idle when you hit the brakes but it does at 10 mph, vacuum is highest at idle so I would check
your brake booster, the booster line is separate from your vacuum tank lines, pull the line and plug it, I bet the stall goes away, a booster leaking internally is common and will cause both of these problems.
Is this a manual transmission car? If so, do you have the clutch disengaged when hitting the brake hard? If not, the rear brakes might be grabbing and stalling the car. Just thinking outside the box......
It is not the timing. I set up the distributor many years ago for all in at 3000 rpm. I just checked it and it goes to 38 degrees advanced at 3000 rpm w/o vacuum advance and plugged.
The vacuum can I have is marked M5 360 12. No verifiable spec on line for this unit but, one thread said it is a B1 unit producing 16 degrees advance at the crank. At 1000 rpm with no vac advance I got 12 degrees. Attaching the vac advance and adjusting the idle to 1000rpm I measured 28 degrees so it does provide 16 degrees.
With vac advanced hooked up max advance pegged at 54 degrees. At 800rpm idle I'm at 26 degrees advanced.
I'll try disconnecting and plugging the brake booster next. Hopefully I can brake hard enough to verify this theory.
It is not the brake booster. I disconnected and plugged the line and it stalls with braking. I've plugged the accessory line previously so it can't be a vacuum problem at this point.
Ive already hot wired the ignition with the positive lead. Perhaps it is a bad ground. Where would be the best place to ground the ignition? From the negative coil terminal to the frame?
Ok, had an issue like this on my 496 when I ran Tripower. With the bowls all at the front, it would want to die from fuel slosh uncovering the jets.
Now, you have a QuickFuel carb. It may be set up for drag racing which means jet extensions in the secondary bowl. This would cause both the primaries and secondaries to be uncovered when you hit the brakes. May be worth pulling the bowls to check it out.
I know this is an old thread but did you ever figure it out? I'm having the exact issue.
