Exhaust Soot
Old Nov 18, 2019 | 07:16 AM
Red Hot 71's Avatar
Red Hot 71
Default Exhaust Soot
My 1971 Stingray often participates in local parades where you putt down the road for a couple miles or I go to car shows. Not a daily driver. (350 w/mild cam/4-barrel Holly carb w/Edlebrock intake. MSD ignition/header side-pipes) Veteran's Day parade I noticed I was blowing black smoke. Not super heavy, but noticeable. Also could taste it. (I have side pipes) Got her home and pulled the plugs. All were covered with black soot. No mis-firing & performance is the same as always. Could it be caused by the hi-test non-ethanol gas I have put in the tank the last (3) times? I usually run the mid-grade. Just trying to figure what happened all of a sudden. Have another Christmas Parade this weekend & am trying to participate in that as well. Thanks in advance for replies.
Old Nov 18, 2019 | 10:23 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
It is not the gas.
Check the idle screws and set with a vacuum gauge.
What heat range of plug are you currently running?
Look down the carb throat when idling.....is there gas trickling out of the boosters? If so.....you need to change out the metering plate/block gasket on that side of the carb......this is VERY common for engines that sit a lot.
Jebby
Old Nov 18, 2019 | 05:02 PM
Red Hot 71's Avatar
Red Hot 71
Have been running NGK UR5/2771 in place of the AC Delco R44TS that were in it when I bought it 8 yrs. ago.
Old Nov 18, 2019 | 05:05 PM
7T1vette's Avatar
7T1vette
Your engine is running ver "rich" (excess fuel being burned) when at low speeds. This is usually a carb adjustment or setup issue. Your engine should be set to idle at about 700 rpm. If yours is set at a higher rpm, you may have been feathering the clutch to keep from running too fast in the parade line. You probably need to drop the curb idle speed and adjust your idle needles to allow more air into the fuel mixture at idle. This is an iterative process, as adding air to a rich engine will also cause the idle speed to increase. Continue those adjustments until you get it to idle well at 700 (or so) rpm and so that any adjustment either way on the idle needles will cause a slight drop in rpm.
Old Nov 18, 2019 | 08:13 PM
MelWff's Avatar
MelWff
How did you end up with NGK UR5 plugs? They cross reference to AC plugs in the 42 and 43 heat range, way too cold. You need to install 44 or even 45 range plugs if you intend to do lots of low speed driving.
Old Nov 18, 2019 | 08:18 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Go to a UR4....this is the most common for street driving and is one heat range hotter.
Jebby
Old Nov 19, 2019 | 06:34 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Take it out and drive it like you stole it. Just blast all the carbon out of there that idling and putting around builds up. I bet it'll clear up.
To Exhaust Soot
