fuel pump upgrade
Nov 19, 2019 | 12:14 PM
fuel pump upgrade
need fuel pump upgrade for 82 vette someone give me a glue of what I need
Nov 19, 2019 | 12:20 PM
Why do you need an upgrade? Are you still running the CFI?
Jebby
Nov 19, 2019 | 01:28 PM
Cruise-In II Veteran
Quote:
Originally Posted by
capnron3
...someone give me a glue of what I need...
An 84 pump.
Nov 19, 2019 | 04:23 PM
yes however, added new heads a modest cam and renegade intake but at 4000rpm it starving for fuel
Nov 19, 2019 | 04:36 PM
EP241: 85-87 Vette TPI pump
make sure your bladders are new
you may need to step up to 80 or 90lb injectors
Nov 19, 2019 | 06:15 PM
Did you check fuel pressure to see how much psi the pump is putting out? Did you replace the fuel filter?
Nov 19, 2019 | 09:30 PM
goin to upgrade pump first ,when you say bladders do you mean diaphragm fuel pressure regulator? can I leave that same spring in regulator?
Nov 20, 2019 | 03:36 PM
Nov 21, 2019 | 11:46 AM
by any chamce fast 81 do u have a part number for injectors or something I need to substitute with
Nov 21, 2019 | 11:50 AM
yes but added heads and cam and renegade intake I found that 82 and 84 pumps r week so I upgraded to and 85 I found out that you can do that with stock xfire motor and get better performance
Nov 21, 2019 | 01:05 PM
heads r AFR 180 65cc I believe 2.02 intake cam is 05 224int 224exh lobe ctrs r 109 int 119 exh lift 466
Nov 21, 2019 | 02:36 PM
capnron:
80lb injectors are from 80's police interceptor cars: Search TJ25
90lb in jectors are from GM 454 SS pickup trucks: Search TJ11
Summit carries both
Check out the 1982 sticky post at the top of this page for more/all info Xfire
Fast81
Nov 21, 2019 | 03:41 PM
capnron3
how is it performing now ??
