Rear strut rods.
Old Nov 24, 2019 | 09:56 AM
kodpkd's Avatar
kodpkd
Default Rear strut rods.
I'm considering installing new trailing arms. I know I am going have trouble removing the lower shock mount. Has anybody installed zerks in the strut rods to keep then lubed. I am thinking about installing high pressure zerks and lube them or BP blast them so they will be easy to remove.
I am thinking a "Grease Buster" would work well.
Old Nov 24, 2019 | 10:37 AM
Tampa Jerry's Avatar
Tampa Jerry
I would not install zerk fittings. Drilling a hole for them will make the casting prone to breaking. Before you try to remove the shock mount, soak the area with Aeroil or a mixture of ATF and acetone. Do this for a few days. Remove the carter pin and remove the bolt. I use a tool designed for the express purpose of knocking out the mount while saving the threads. You can get the tool for $15-$20 at the larger vendors. Screw the tool on and hit it with a 3 to 5 lbs. hammer. If it does not come out, add some heat. I got mine out and cleaned them up on a wire wheel. Upon installation, I used a generous amount of anti-seize on the mount. That should do it. Jerry
Old Nov 24, 2019 | 11:55 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The issue is either the bushing is shot, or the inner sleeve is rusted to the shock bolt. We use the shock removal tool and a quality impact hammer and they always come out. You might want to squirt some lube in there a few days before you give it a try though. Putting a zerk in will compromise the strut rod and you're not going to get lube to the inner sleeve by doing this anyway.
Willcox
Old Nov 24, 2019 | 07:01 PM
Peterbuilt's Avatar
Peterbuilt
After removing the cotter pin and castellated nut screw on a 3/8 inch pipe cap and hammer away.
Coat the shock mount with anti-seize before reinstalling.
Old Nov 24, 2019 | 11:00 PM
Bikespace's Avatar
Bikespace
This is what I had to do to get my shock mounts out.
Totally worth it, though. Consider heim-jointed strut rods, if you go through all that trouble anyway.
To Rear strut rods.
