ring and pinion advice
Old Dec 2, 2019 | 05:48 PM
Z06CE's Avatar
Z06CE
Default ring and pinion advice
I have a 69 BB with a 4 spd M20
I have verified that the gear set is 3.90 to 1 and I don' like it. 3000 rpm at 58 MPH.
I'm thinking of going to a 3.36 to 1.
This car will not be going to the drag trip. I want the car to be driveable foe the street.
Advice will be appreciated
Old Dec 2, 2019 | 06:13 PM
ralphspears's Avatar
ralphspears
Banned Scam/Spammer
Sounds like 4:11 ratio there Is no 390 gear ratio in a corvette go with the 336 gears
Old Dec 2, 2019 | 07:32 PM
Z06CE's Avatar
Z06CE
Im almost certain the gear is not original to the car.
It is a 3.90
Old Dec 2, 2019 | 08:19 PM
GTR1999's Avatar
GTR1999
390 was offered long ago by GM as a performance gear, Richmond Gear also offered it. It was never a production gear ratio.
Your 427/390 HP M20 will work fine with a 336 gear. Some came with a 308 as well and the BB torque will drive 1st gear as well. I have built several of them and the owners were all drivers, no racing, and really liked the setup.
You will want to confirm the year of the diff though in case it was replaced. There are some variances in them from year to year, not with bolt in application but with strengths and weakness of the parts. Since you have a 390 it was built for some performance and most likely abuse so you will want to know there are no issues with it.
Old Dec 3, 2019 | 11:48 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
I really enjoyed my 427/400 with the M20 and a 3.08.........plenty of torque and nice to cruise on......
Jebby
Old Dec 3, 2019 | 12:44 PM
CanadaGrant's Avatar
CanadaGrant
Jebby
My 69 427/390 has an M20 and a 3.08 and I wouldn't want anything more for gearing. Who wants to be cruising at 3000 rpm just to do the speed limit? The thing is a torque monster anyway.
Old Dec 3, 2019 | 01:47 PM
Z06CE's Avatar
Z06CE
Jebby
This is true since I have more torque after the rebuild..make sense
Old Dec 3, 2019 | 06:49 PM
OldCarBum's Avatar
OldCarBum
As part of the resto/mod to my 73 I'll be running a 496 with a TKO-600RR (.82 5th gear) and 3.08 rear end gears.
I'll be able to cruise at 2181 rpm at 70 mph in 5th.
With the 1.0 4th gear in the M20 you should be about 2660 rpm at 70 mph.
Nice!
Old Dec 3, 2019 | 07:50 PM
Z06CE's Avatar
Z06CE
Nice!
Are those numbers for the M20 with the 3.08 gear?
Old Dec 3, 2019 | 09:02 PM
WA 2 FST's Avatar
WA 2 FST
I'm with the consensus here. Go with a 3.08. I had a '69 a decade ago with ~525hp and 540tq (flywheel... I dyno'd it at the rear wheels, so I'm extrapolating the numbers for flywheel) and I had a Richmond 5-speed in it which has a 1:1 high gear, just like your M20. 3.08s were great on the highway at 70-80mph, which is what everyone runs here where I live, it seems. Granted, that transmission had much lower and closer 1st-3rd than yours has, but I think even with your M20, you will have plenty of low-end TQ. You'll probably be able to do 50-55mph in 1st gear, too... and that can have its advantages if you're not boiling the tires.
Old Dec 4, 2019 | 08:58 AM
Mr Sidepipes's Avatar
Mr Sidepipes
running a 3:36 that Trac-Dog did 2 years ago and it is a pleasure on the street now with a new Auto-Gear wide ratio M-22, with the solid lifters it really winds up and has a wicked long 1st and 2nd gear
Old Dec 4, 2019 | 09:42 AM
Z06CE's Avatar
Z06CE
My 427 has been rebuilt 60 over with a Howards hydraulic roller cam now. Its a mild cam.
Basic rpm range 1600 to 5000 rpm
Lift in and exh .555
Intake Duration @ .050: 219
exhaust Duration @ .050: 227
lobe separation: 110 deg
good idle , performace street, great low to Mid range
Using the Rochester quadrajet which I'm very happy with..
The 3.90 gear is way to much gear because its not utilizing the rpm range where all the torque is.
The 3.08 might be the answer.
Old Dec 4, 2019 | 10:59 AM
OldCarBum's Avatar
OldCarBum
My gear ratio calculator shows with your M20 transmission you have a 1.0 4th gear ratio and with a 3.08 rear end gear you should be turning about 2660 rpm at 70 mph.
The calculation is using a standard 27" tall tire.
Your actual rpm at 70 mph may differ slightly depending on your actual tire diameter (26.5 diameter tire will bring the rpm's to about 2697 at 70 mph).
Old Dec 4, 2019 | 12:25 PM
Gunfighter13's Avatar
Gunfighter13
Your best option would be this.
https://shiftsst.com/blog/post/1968-...ctfit-kit.html
But I agree with the rest 3.08 gears with your 4 speed and engine would work well.
Old Dec 4, 2019 | 01:13 PM
Z06CE's Avatar
Z06CE
I probably would have opted for the Tremec 5 spd but I already spent money rebuilding the Muncie... about $1800.00. Should have done more research but I did not know that there were 3.90's in the rear at the time. I had already pulled the engine when I first purchased the car because of big engine issues.... so since the engine and trans was out I had the Muncie checked out and rebuilt.
Old Dec 4, 2019 | 01:26 PM
OldCarBum's Avatar
OldCarBum
I would install the 3.08's and enjoy the improvement.
If you want to lower your highway rpm's even more in the future, save your pennies and pick up a Tremec 5 speed.
You could recover some of the cost by selling your rebuilt M20.
Old Dec 4, 2019 | 09:45 PM
hawgn68's Avatar
hawgn68
Default Wanna Trade
Z06CE, I have a 3.08 HD differential with yokes, AW code that I’m trying to trade for a 4.11 or close (3.90 would work). It’s listed with pics in the C3 parts for sale/trade. I have the 3.08 gear in my 68 with the M20 and with my 27” tires, it turns 2400 at 60, 2600 at 70. Great cruising gear. Changing a pumpkin is a lot easier than changing a ring and pinion. I’m in Missouri.
Jimbo
To ring and pinion advice
Old Dec 4, 2019 | 10:00 PM
Z06CE's Avatar
Z06CE
Jimbo
Is the gear on your car now?
My 390 is still in my vette.
I'm in Palm City, Florida
Old Dec 4, 2019 | 10:15 PM
hawgn68's Avatar
hawgn68
Z06CE
No, this is a spare complete differential I bought a while back with the intention of putting a bigger gear in it for my '73 Vintage Race car to run on short tracks. It appears to be ready to "plug and play" after a wire brush and some black paint. I have family all over Florida (I grew up in Micanopy), but don't know of any trips upcoming. My email is: kjhawg@outlook.com
Jimbo
Old Dec 4, 2019 | 10:18 PM
Z06CE's Avatar
Z06CE
Z06CE
Jimbo
Can you post the link to your gear?
