amp meter to voly meter
Old Dec 4, 2019 | 09:56 PM
TPI BOY's Avatar
TPI BOY
Default amp meter to volt meter
What's the best corvette volt meter to use? I have a 75
I see 77 then 78 to 82,volt meters
Old Dec 5, 2019 | 12:11 AM
C3 Stroker's Avatar
C3 Stroker
It doesn't matter which one you use, they all are wired the same. For your '75, I would use the 72-74 volt gauge since it would match your other cluster gauges and fit right in place.
This one........https://www.zip-corvette.com/72-74-v...gine-swap.html
Old Dec 5, 2019 | 04:18 PM
7T1vette's Avatar
7T1vette
The C3 used AMMETERS in gauge clusters thru 1976. VOLTmeters didn't come into the clusters until 1977.
So, do you want to CHANGE from an ammeter to a voltmeter? Or do you just want to replace the ammeter?
In either instance, you need to verify that the meter actually needs replacing before spending the money. Most "gauge" problems are sensor or wiring related, rather than the meter being defective.
Old Dec 5, 2019 | 04:27 PM
TPI BOY's Avatar
TPI BOY
i want a volt meter. For sure the amp meter is shot
Old Dec 5, 2019 | 06:56 PM
TPI BOY's Avatar
TPI BOY
I used zips chat on that liink and he said it would not work
Old Dec 5, 2019 | 07:01 PM
'75's Avatar
'75
The size and shape of the 77 to 82 volt meters is the same, but the face is slightly different, function is the same. On mine, I taped up the wires from the old ammeter and got volt meter power from the gauges.
Old Dec 5, 2019 | 07:08 PM
TPI BOY's Avatar
TPI BOY
is not the back where the wires go diffefent.
Old Dec 5, 2019 | 07:18 PM
'75's Avatar
'75
Different than the ammeter, but all the volt meters have the same terminals.
Old Dec 5, 2019 | 07:22 PM
TPI BOY's Avatar
TPI BOY
Dont the 78- 82 have the printed circut
Old Dec 5, 2019 | 07:26 PM
'75's Avatar
'75
Yes, but the gauges are the same on the rear as the earlier ones.
Old Dec 5, 2019 | 07:30 PM
TPI BOY's Avatar
TPI BOY
Old Dec 7, 2019 | 06:41 PM
mrvette's Avatar
mrvette
OP, junkyard a VM from an 80's Chebby pickup......look close, they are the same except a slight print diff on the meter face.....
To amp meter to voly meter
