My First post! GM Performance Cam 3863151 Question.
Old Dec 5, 2019 | 02:54 PM
sdcc's Avatar
sdcc
3rd Gear
Default My First post! GM Performance Cam 3863151 Question.
Hey Guys,
I just picked up a 76 L48, Auto. The guy i bought it from had the engine rebuilt 5 years ago. According to him its a stock freshen up. I just got a great deal on a "New in Box GM performance, Cam Lifter kit part # 12364050" its 15 years old but never taken out of the box. According to the cam card it has the same duration and lift as a GM 3863151. I have a set of summit 1.6 roller rockers from another project id like to put on. According to my calculations that will bring it from .447 lift to .477 is that exceptable for new stock valve springs?
Old Dec 5, 2019 | 03:27 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
No.
Buy a set of "Z28" 1.250 springs from Elgin on E-bay or other sites......much better spring overall to handle .480 lift and they are a drop in......in fact.....get the whole spring, lock, retainer kit and some umbrella seals......
https://www.ebay.com/itm/Elgin-Z28-S...oAAOSwAGhdoOAX
The other issue is that with stock GM heads....it is a crap shoot if the 1.6 rockers do not move the pushrods in so far as to rub on the head.....you HAVE to check this....some do, some do not.
The car in my Avatar was my 66' L-79 Vette......it had a .447 lift stock L-79 cam in it with 1.6 rockers but it had guideplates......it ran VERY well for a 331 inch engine through manifolds......
Jebby
Old Dec 5, 2019 | 08:20 PM
wilcar's Avatar
wilcar
Not sure if your 350 still has the stock low compression pistons but if they are then you are probably at 8.0 c r. I had a 76 L82 Auto with a 3.36 rear and it was a little doggy off the line. I later went with a Isky 264 Mega cam with 216 216@ 050 .450 .450 lift 108 lsa and it made a huge difference in low and mid range compared to the L82 cam. If you had a 4 speed you could get by with the L79 cam. If you find the L79 is doggy for you then maybe a 3.73 gear would help.
Old Dec 6, 2019 | 11:24 AM
gkull's Avatar
gkull
First of all you need to understand that NONE of those old GM cams are performance enhancement. NONE, ZERO compared to modern lobes and springs.
Also the expense of installing a cam with minimal lift and duration changes without other engine enhancements will result in minimal gains
You also stated that it was some sort of newer version rebuilt engine. Your score on the GM cam could feasibly be a step backwards
50 year old GM stuff is really just junky. Even my new 79 l82 was not a performance car
Old Dec 6, 2019 | 12:06 PM
cv67's Avatar
cv67
St. Jude Donor '05
x2 use a better cam. Some are in love with that old stuff its not worth the labor. Absolutely dont use old/stock springs when changing cams.
Even an old tech Isky 270 which is close in spec will outperform the GM all day.
Old Dec 6, 2019 | 12:22 PM
sdcc's Avatar
sdcc
3rd Gear
You also stated that it was some sort of newer crate engine. Your score on the GM cam could feasibly be a step backwards
Its suspose to be a new ring, bearing, valve rubber and gasket upgrade. I got the cam and lifters for $100. I have a period correct Eldebrock RPM Preformer intake that's a spread bore and I have Hooker long tub headers and one of there 2.25 dual exhaust to go on too. I'm just looking for it to work better than the 180HP it came with. When the time/money allows I have another 4bolt block that will be a Monster!
Old Dec 6, 2019 | 03:46 PM
jackson's Avatar
jackson
Originally Posted by sdcc
Hey Guys,
That's not such a great deal unless you really needed a 151 cam & lifters. As others said, you can do a lot better. Keep the lifters and use them on a better HFT cam. Fleabay the 151.
Summit has more than a dozen house brand HFT sbc cams ... all under $100 ... several would be better than 151 for a 350 w/auto.
As others said, install new springs with new cam; as said Z28 springs are good for most HFT up to about .480" lift.
Suggest first pay attention to assuring both carb & ignition are properly set up, optimized & tuned. If admissible in your locale, true dual exhausts will help a lot.
-addendum-
Remember, a '76 L48 has relatively LOW compression ... if it was just a "freshen up" it still has Low compression; remember that going forward w/ hi-po plans.
Old Dec 8, 2019 | 09:10 AM
stingr69's Avatar
stingr69
The problem you have is lack of static compression. The stock 76 L48 engine is a typical smog era type with low compression from the factory. The "151" cam requires more static compression to work right. If you put that "151" cam in a low compression engine you will end up with a soggy bottom end and no real performance increase. Swap the heads for something with smaller combustion chambers would increase compression. That would help make that cam work better but it might not be in your budget at this time. I actually do like that cam and its younger brother the 350/350 cam if the rest of the engine is built right for it.
In my opinion - The right way to move forward is to run the Comp 268H cam. It was originally designed specifically to work in your stock smog era L48 and give you a performance increase while still working well without a lot of additional mods and expense. You can do additional mods to add to it later as your time and money allow.
Old Dec 8, 2019 | 05:35 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
I agree......if you have to use the 151 cam...do it, but the 268H Magnum is much better and is still a nice shot of life for old 350's......
Jebby
To My First post! GM Performance Cam 3863151 Question.
