Has anyone out there put together a turbo build using a 4.8 engine. I was originally on the hunt for a junk yard 6.0 ls but as fast as the junkyard receives one they are gone in like 3 days. Its so bad that I think the workers pull them for other businesses as a side hustle. So right as I started to look into the 5.3L I read the engine specs for the 4.8 and to be honest this seems like the perfect donner for my OBS Truck. I"m only looking to clear 500-600 on the wheels. 500 would be really good 600 would be my max I would want for this truck. The things that seems to deter other racers is what I like about the engine:
Smaller Stroke - means I could probably rev the snot out of it
Low Compression - perfect for my turbo application
Availability - plentiful as a matter fact I see other people in the junk yard walking away from them even fully intact engine
Displacement - I know it's small but the turbo should more than make up the difference so, I think
IBeam Rods - I normally shoot for H-Beam but I'm looking for this engine to rev pretty hard and the I-beams are lighter
The only thing I'm unclear on is the PCM in them. I'm looking for one that does real time tuning but it's not a deal breaker, I just need to do my homework. So I'm asking the question has anyone built a turbo junkyard 4.8 and is the juice worth the squeeze. I only want to add new springs, cam (not sure I need cam since I will turbo) and possibly methanol to keep it running cool. I just don't see the need to waste money on that since my hp goals are low. I don't plan on forging the pistons and rods unless I have to. I do plan on porting the heads but it will be a home porting vs purchasing aftermarket ones. The end state is to have a fast revving torquey engine that smokes the snot of tires and sound nasty. 500rwhp is plenty I think 600 is just the icing on the cake. please provide any comments that you feel will aid in the research.
Fyi, the hyd lifters and springs will limit your rpm to 7000 or less rpm so I think any bottom will take that. 4.8, 5.3, or 6.0 bigger the better would work best.
Yes the LS 4.8 will be going into a GMT400 OBS truck. I want to run a turbo on the 4.8 or 5.3 engine. It's just I was hell bent on this 6.0L but after doing some reading it looks like the 4.8 or 5.3 can hit the 500+rwhp with no problem I'm just asking the question is there anyone out there hitting these numbers without upgrading rods and pistons. I know the crank and block can hold up to 1000hp .
