Looking to lower the rear end
If that were my car, I would not hesitate to put on a Van Steel low-arch monospring, perhaps one that has been shortened 1/2" on each side. From what I can tell, their low-arch springs are similar to the VB&P springs. The Hyperco springs are likely similar to the high-arch TRW springs that cause the same problem you are trying to fix with your steel spring. Certainly call them first, though.
Here's a shortened VB&P monospring in my 80, with 8" bolts.
Don't remember which one I removed, but I guess the effect differs with which leaf you remove so there might be some trial and error involved. Anyway, a simple job.
If your goal is to improve your car's performance, you may change your mind about the composite spring once you remove that heavy steel spring bundle.
FWIW, my understanding is that the wrong composite spring will raise the rear, but the correct one will not. TRW and the high-arch Van Steel springs will raise the rear. VB&P and (I've heard), the Van Steel low-arch springs will not raise the rear. The correct spring can also stiffen the rear, while still providing a smoother ride (this was certainly my experience). Stiffer may be doubly important now that you have reduced the total suspension movement. To keep from bottoming out and riding on the bump stops, you may want a stiffer spring.
Good luck, and please keep us posted!
I would remove nr 3+6 from the top or something like that, and then try it. Ok it is some work but you'll do it in an hour or two.
Note! If you remove two or three leafs, the spring mounting bolts, or at least two of them (the ones not drilled thru in the diff mount) could possibly bottom out in the mounting hole. Measure this, or you could end up not knowing this, and just torque the bolt against the bottom of the mounting hole!
The angle of the tire (camber) is determined by the lengths of the two arms attaching it to the center diff (driveshaft and strut rod), these two work in conjunction to one another. The strut rod is always angled down, so the absolute distance (horizontal plane) from the differential will ALWAYS increase when the suspension is compressed and it swings upward. This will have the effect of angling the tire in at all times.
When the driveshaft is level and parallel to the ground, the distance from the rear to the tire is at it's maximum. From this point, with any suspension travel, that absolute distance will be reduced as the driveshaft is essentially an arm swinging in a radius from the pivot point on the diff. Since the driveshaft is the upper link, the absolute distance from the rear to the tire is reduced, this will tilt the tires inward, increasing the camber. C3s like to squat upon acceleration, and this creates an uneven/reduced contact patch for the tires. Same thing in turns. This is compounded a bit by the fact that the strut rod will always want to tilt the tire inward.
With the driveshaft angled downward at rest, when the suspension travels upward, the distance from the diff to the tire (horizontal) will change and reach it's maximum as the driveshaft passes through the horizontal plane, and then it starts reducing again, reaching the starting distance when the suspension is at a point where the driveshaft is now angled upwards the same number of degrees (but in opposite direction) as when it was at rest. This combination is till not perfect, but it keeps the most tire on the ground at most times. When lowering bolts are solely used, you lose this effect the closer to the horizontal the driveshafts are at rest.
The Chevy Power Book's solution to properly lower the rear of the car is to remove the rubber mounting bushings from the differential mount crossmember and replace them with welded in steel discs, this will lower the chassis onto the differential, lowering the ride height and allowing you to keep geometry correct. I did this on my car, and it in conjunction with the VanSteel coilovers worked well. A lower arched spring should have the same effect, but it will reduce the total amount of suspension travel some, probably not a big deal.
Just trying to provide a little info to inform you in your decision.
The Corvette rear suspension is both one of a kind, unique, peculiar, and hard to understand. But it actually works quite well. There are however many incorrect myths about it as well. The camber curve of the rear suspension is controlled by the Instant Center where the strut rod line intersects the half-shaft line. For a stock C2 it is 48" and for a stock C3 it is approximately near the opposite tire. Because of this the rear of a Corvette has a large negative camber gain on jounce. (Rebound is positive but mostly irrelavent). The gain is relatively constant regardless of rear ride height. Many have found that the negative camber gain in the rear is too great and needs to be reduced. This is accomplished by lowering the inner strut rod mount. Lowering the strut rod mount around 1" can make the strut rods and half-shafts absolutely parallel. This would move the instant center to infinity, and would have zero camber gain, and could be useful to drag racers. A 1/2" lowering seems to be a more common adjustment for handling.Whether this is beneficial or not depends on all the other suspension parameters.
I wrote an excel spreadsheet just for C3s, which allows you to see the results of suspension setup changes in a dynamic and interactive manner.
Download link here:
https://drive.google.com/file/d/12gJ...ew?usp=sharing
Duntov's Rear Camber Curve here:
This is the C2 Rear Camber Curve. Lowering the rear strut lessens this.
To the OP's question of removing leaves to lower the rear: That is complicated. Multi-leaf springs are designed as a system. Adding a leaf adds both load capacity and rate and raises the rear. Removing leaves does the reverse but additionally makes the spring fatigue quicker, thus it will settle, wear out and droop under use. As these kinds of changes are pretty unpredictable, they can be frustrating. I would recommend having the spring professionally corrected, or buy a new one, preferably composite.
Download link here:
I don't want to hijack the OP thread here, but just wanted to make a couple of points/pose a few questions.
- I am in total agreement that having the half-shaft parallel to the horizontal puts the load on the U-joints at it's lowest
- Lowering the body by raising the diff allows you to lower the body, and not change the suspension characteristics as you have not changed any of the angles which determine the Instant Center, that was my point above
- It would seem that if you angle the half shafts down a bit, you increase the Instant center as the point of intersection of the half-shaft and strut rod will be moved further away than if the half-shaft is at the horizontal plane. This has the same effect as lowering the inner strut rod mount point does, it just does it by changing the other line.
- When the half-shaft starting point is below the horizontal, wouldn't the total change in camber be smaller throughout the suspension travel range? This would be because the travel of the half shaft from below the horizontal to the horizontal would have one effect which would then be offset by the same amount at the point where the half-shaft is above the horizontal by an equal amount as when the car is at rest. So doesn't the car hold tighter to the original camber specification in this layout than when starting from horizontal because when you start at the horizontal, you only have one direction of travel.
- It's only the intersection of the two lines that matter. And there is only one intersect point.
I'm going to have to think on this a while. If I have questions I will follow up in a PM. Thanks for the info/discussion.
And thanks for the excel sheet compliment. I knew there would be a couple people out there that got a kick out of like I do.
Metalhead I bow to your considerable handling expertise. I have seen your car run in your videos and you obviously have it "well dialed-in". Your real world tuning experience & comment just gave me another "ah-ha" moment and explained the graph below.
I found this rear bump curve in Duntov's book, and the shape of it can only be explained as you describe., Varying the height of the outer half-shaft would tilt the bump curve below. He must have had a certain amount of droop in mind to generate an almost flat toe-in bump curve in the 2-3 inch of jounce range that is so critical to handling. The curvature itself is controlled by the length of the Instant Center. But you can see that the curve is tilted & not symmetrical. Greenwood does indeed recommend a 1/2" lower outer half shaft setting for optimum handling.
In response to the original OPs question I have seen Vettes where these half-shafts were tilted down severely, or tilted up severely in attempts to either raise or lower the car. It's just not a good idea to stray too far from Duntov's original plans on ride height. Yes the Vette suspension is more complicated and adjustable than most. That also means it is easier to "foul" it up. We just have to remember that he was smarter than the average Joe!
This is good information, and well thought out. It makes you wonder why GM went with this design, considering the inherent "flaws" that it possesses. On the other hand, considering that the design was on the drawing board in the 1958-59 timeframe (for a late 1962 release, for the '63 Sting Ray), and tires had only about 3" of tread width, it wasn't as big an issue, as in later years.
I think it is truly amazing this design is holding it's own with the passage of time as well as it's doing!
Excellent point on the Toe. I knew this, it just didn't click at the time I wrote the response. Great add.
