Fiber optics troubleshooting...
Old Dec 18, 2019 | 04:10 AM
Daveinspain's Avatar
Daveinspain
Obsessed
2025 C3 ('68-'73) of the Year Finalist - Unmodified
Default Fiber optics troubleshooting...
Sorry if this is been ask a million times but I used the search feature here and everything else comes up but...🤨
All my lights work but the interior fiber optics only indicates the license plate light. I took off the 4 screws to the dash panel to see if the connections were good there. Everything looks good. I broke the hot lead to my cigaret lighter, damn... So today after I fix the cigarette lighter lead I’ll continue looking for the optics problem... Any heads up on where else to look?
Old Dec 18, 2019 | 05:54 AM
derekderek's Avatar
derekderek
fiber optics are pure mechanical. the optic lead is stuck into the tail light body. picks up the light and the other end lights up at the console. first check the rear lights to see if FO lead has pulled out. if the optic cable has been broken or cut, there are youtube repair videos to reconnect them.
Old Dec 18, 2019 | 05:55 AM
sug's Avatar
sug
2020 Corvette of the Year Finalist (stock)
C3 of Year Winner (stock) 2019
Have a look at all the connections at the tail lights ,park lights and head lights to make sure they are in there appropriate grommets and have got the proper lenses on them .The fibre optics run with the wiring looms ,so check for broken fibre optic cables .My 69 ones were not working when I got it and found they had been cut by the previous owner for some reason
Old Dec 18, 2019 | 12:32 PM
Bergerboy's Avatar
Bergerboy
Also check that the lenses inside the tail light housings are clean and clear.
Remove the light lenses and inspect.
I had an easy fix, in that the P.O. had re-sprayed the car without properly masking off the housings (at least he removed the light lenses).
So there was a decent amount of blue overspray on the FO lenses.
Once I cleaned them off and reinstalled - I got much better light transmission.
And as others have stated already - lot's of tips out there on the Internets!
Old Dec 18, 2019 | 12:40 PM
7T1vette's Avatar
7T1vette
If the car has been repainted, odds are that the lamp housings got some overspray in them and those plastic 'lenses' the F/O cable fit into are painted over so little or no light gets thru to the end of that cable. There must be clear path of light transmission for light from any lamp housing to get shown on a lens in the console display.
Old Dec 18, 2019 | 01:17 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Also clean the lenses in the console. They can get crudded up. Soap, water, and an old toothbrush worked for me.
Old Dec 19, 2019 | 06:05 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
And to be clear they transmit light, not electricity, so using the blue compression clips to crimp them together wont work, like my PO did to all mine........
Old Dec 19, 2019 | 08:33 AM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
Talk about a Bubba move there.
Old Dec 19, 2019 | 09:01 AM
Rescue Rogers
If that harness is still around I'll post some pics
To Fiber optics troubleshooting...
