Exhaust Flange Studs
Old Nov 17, 2002 | 11:54 AM
l2vette's Avatar
l2vette
Default Exhaust Flange Studs
Does anyone have a suggestion on removing old, crusty exhaust flange studs?? I broke one, when removing my pipes and I've tried everything but removing the exhaust manifold.
:confused:
Old Nov 17, 2002 | 12:52 PM
mapman's Avatar
mapman
Default Re: Exhaust Flange Studs (l2vette)
I had my exhaust manifolds off (had pulled the engine), soaked studs threads in PB Blaster etc. Two of them broke off and I had to (carefully) drill them out and use one of those wedge shaped stud removal tools (Sears), and some gentile persuasion.
:smash:
If it isn't broken off too close to the manifold then there are some stud removal tools that attach to a 1/2 inch drive ratchet.
However, its probably going to take you less time to remove, work on, and replace the exhaust manifolds than to remove the stud while its in the car. :sad:
Old Nov 17, 2002 | 12:54 PM
Green76's Avatar
Green76
Heat the exhaust manifold untill red hot where the stud screw in and use wisegrip pliers and unscrew.
To Exhaust Flange Studs
