'73 Speedometer
Old Dec 21, 2019 | 01:22 PM
Elcransonator's Avatar
Elcransonator
Default '73 Speedometer
Ok you guys cut me some slack here/only had the car about a month. Anyway I've searched here and seen dozens of threads about speedo issues and lubricating the speedometer cable. What I haven't seen is a definitive answer to this question:
If I come to a complete stop and my speedometer reads 30 mph, does that definitively mean it's the gauge and not the cable? The speedometer seems to be fairly accurate at highway speed, just doesn't go to zero at full stop. You can leave it in garage a few days, then go look and it will have returned to zero.
Old Dec 22, 2019 | 03:26 PM
MelWff's Avatar
MelWff
Its the gauge. The cable isnt moving when you are stopped. The head of the speedometer may have old grease preventing it form easily returning to zero.
Old Dec 22, 2019 | 07:52 PM
Elcransonator
Yeah that's kinda what I figured, just wanted to make sure. So how hard is it to get at the gauge? Thanks in advance for the tips!!!
Old Dec 22, 2019 | 08:28 PM
MelWff's Avatar
MelWff
You should get a copy of the factory Chassis Service manual. You have to drop the steering colimn and pull forward the driver side dashboard.
Old Dec 23, 2019 | 08:54 AM
Elcransonator
I have the shop manual, is that the same?
Old Dec 23, 2019 | 12:57 PM
MelWff's Avatar
MelWff
Depends, is it a copy of the factory manual or something else like Hanes or Chilton?
https://www.zip-corvette.com/73-shop...SABEgIqKPD_BwE
Old Dec 24, 2019 | 08:39 AM
Elcransonator
This is what I have.
Old Dec 24, 2019 | 12:54 PM
MelWff's Avatar
MelWff
That is a generic book covering many years, the link I gave you is for 1973 only.
Old Dec 24, 2019 | 04:39 PM
Elcransonator
Ok cool thanks for the tip/I'll get that one. I read somewhere that "service manual" was bad, like basic stuff/not how to work on one.
Old Dec 25, 2019 | 11:50 AM
oVoSanto's Avatar
oVoSanto
When I replaced the tacho in my '74, i had to remove in this order:
- all the windshield trims
- upper dash pad (cracked during removal )
- center console
- lowered the steering column
- driver dashboard
Old Dec 25, 2019 | 07:20 PM
caskiguy's Avatar
caskiguy
http://repairs.willcoxcorvette.com/category/speedo/
http://www.corvettemagazine.com/tech-articles/1968-1977-corvette-speedometer-tachometer-repair-installation/
Old Dec 26, 2019 | 11:56 AM
caskiguy's Avatar
caskiguy
http://www.corvettefaq.com/c3/RebuildSpeedo.htm
To '73 Speedometer
