Booster brake install issue
Old Dec 23, 2019 | 01:18 PM
SJRedC3's Avatar
SJRedC3
Cruising
Default Booster brake install issue
I own a 1971 4 speed and I am trying to convert the brakes from manual to booster. A problem developed where I cannot get to the upper left bolt under the dash. The clutch arm is in the way. My question is can if I remove the dash can I get to the bolt from there?
Any advise would be helpful.
Thanks,
SJRed
Old Dec 23, 2019 | 05:18 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Yes. And the job is much easier removing the steering column and then the dash.
Old Dec 23, 2019 | 06:26 PM
SJRedC3's Avatar
SJRedC3
Cruising
Thank you for your response. Yes we ended up removing the steering column and now the dash. Again thanks for your help.
SJR
Old Dec 26, 2019 | 08:51 PM
PGPierce's Avatar
PGPierce
I would Not remove the dash,it’s a awesome pita job,remove he clutch mechanism arm.
Old Dec 28, 2019 | 09:39 AM
Plasticexperience's Avatar
Plasticexperience
You can remove the clutch/brake pedal assembly, its not that hard to and it makes that last bolt easy. I have removed it without taking anything out - a pita job, but possible. Bob Messina
To Booster brake install issue
