fan clutch replacement
Old Nov 17, 2002 | 08:26 PM
wes76's Avatar
wes76
Default fan clutch replacement
Is anyone familiar with the thermal fan clutch offered by Summit and do you think it will fit on my 76 350??
:cheers: :cheers:
Old Nov 17, 2002 | 11:54 PM
bigvette1's Avatar
bigvette1
Default Re: fan clutch replacement (wes76)
Not that specific one, but a good thermal clutch fan with the correct pilot hole for the pump will work fine. I have used the ones from AutoZone made by Imperial and they work great and are reasonable.
Old Nov 18, 2002 | 09:07 AM
Alwyn678's Avatar
Alwyn678
Default Re: fan clutch replacement (bigvette1)
Advance Auto Parts also sells them fro like 60 bucks or so
Old Nov 18, 2002 | 11:25 AM
Bobchad's Avatar
Bobchad
What is the difference between a thermal fan clutch and a regular fan clutch?
Old Nov 18, 2002 | 12:35 PM
bigvette1's Avatar
bigvette1
Default Re: fan clutch replacement (Bobchad)
The thermal clutch fan uses a bi-metal strip with the internal clutching mechanism to "engange and disengage the clutch and fan based upon a temp range. The non thernal uses internal fluid that due to temp expansion engagues and disengauges the clutch and fan. Which is best? Both work well, however the thermal with the bi-metal strip seems to be more accurate and does not lose RPM's in fan rotation as quick as the other. The origional GM's were non thermal and replacements are the thermal. Hope that helps.
Old Nov 18, 2002 | 12:44 PM
Bobchad's Avatar
Bobchad
Thanks.
To fan clutch replacement
