If you wanted to reference the original cam specs for a particular C3 engine as far as lift and duration, where would you search for that if still available info?
Your profile states you have a "race cam" is that the cam you need the specs for?
Can you provide some detail whether you need to see every camshaft used in every C3 or you need a specific one?
No I have the specs for that, I would like to get an idea what originally came with the base engine. I have 218 duration at .050 lift with this but doesn't idle below 1100 rpm very well. I'd kind of like to know what came with the Mark IV 270hp BB. This info may not be at your finger-tips any more. Thanks.
Specs are available but not very useful. The designs are not comparable to aftermarket cams due to the long slow OEM ramp rates. Best to compare aftermarket cams to aftermarket cams.
218 @ .050 is very mild for a Big Block........it should idle very well. I believe you have other issues. Go through and check timing....set at 36 degrees @ 3000 rpm and let the initial fall wherever it falls. (Do Not go by the GM initial spec for timing). Also check vacuum advance for proper operation and that the mechanical advance mechanism is free and moving as it should.
Jebby
OK maybe I do have other issues... Anything under 220 duration should be good and easy to handle I've read. So possibly I can rule out the cam as a problem. Thanks.
After you get the timing straight, look for vacuum leaks and carb idle. I have a 229/229 camshaft on a 109 LSA and it idles under 1000 rpms.
Thanks for the video, that does idle smooth it seems. Only I may not have any glaring issues with timing or vacuum as I just had the engine tuned at a very expensive Classic Speed and Custom shop less than 500 miles ago. They said they would set the timing to the GM setting called for. The engine was just rebuilt at another shop. I did not change the cam because I liked what I had previously. I did drop the compression to 9.5 going with different pistons. I changed the intake from a performer to a RPM which gave it a little more top end but took away bottom end.
The spark plugs appear to be firing exactly as in the previous engine with the same plugs getting gas fouled at lower rpm. The exact same cylinders so I tend to think it's the cam. Compression is very good all cylinders.
The cam was very popular back in the day they tell me and has .518 lift. But it is old school, and was thinking maybe switching to a modern cam may clean up the low rpm fouling problem?
Why would they set the timing to stock GM if the cam has been changed? GM timing specs are there more for emissions. A lot of time the timing can be advanced more and it will run better. Having changed the intake it is possible a gasket did not seal properly and there is vacuum leak somewhere.
I think I'll check in with them after the holidays and get them to advance it and check for leaks etc. Getting a modern performance cam may help I don't know. I'll have to ask around with experts on it. Getting the right cam is critical some say and there have been quite a few advancements with cams but may need to have computer technology operating with them to function.
Also GM timing specs are set to lower the power output. Easiest way to make a 300 hp engine 235 hp is retard the timing
They must know that about factory timing specs and relation to HP, what would the advantages be? A cooler running engine, a richer mixture and better for break-in on a new engine? I best get a timing light and see where it is at, my old light is toast. I'll try bumping up a couple degrees but I doubt that will completely correct the plug fouling on a few cylinders that are a problem.
What spark plugs are you using, manufacturer and part#?
AC Delco R45TS for 5 cylinders that are doing well. NGK UR56P for the others that are having some issues. The iridium plugs do help it seems but I have not lowered the idle yet, it is still about 1050 rpm after warming up. Takes about 5 mins this time of year to get warm so I throttle it to keep revs up. It has an auto choke that is disconnected and I might connect for winter driving.
I checked the timing and it is at 16 BTDC which is factory. I'll check with the shop I'm working with about advancing it and see what they say about taking it to 36 BTDC which I see has been recommended on this forum in other threads.
I'm still thinking a cam change would eliminate possibly these issues.
run it to 3k and see where your total is bet it runs a lot better. now its retarded low on power and I bet running warn. Thats a lot of your idle problem.
260ish@050 and can idle under 1100 easy. Its timing.
Perhaps there's been a mix-up/misuse between stated duration of the two Common but Different standards: Advertised versus @0.050" lobe lift ?
e.g. three hydraulic Flat tappets: a relatively mild Comp 260H High Energy duration is BOTH Advertised 260* while 212* @ 0.050" lobe lift ... in a 350, it'll idle good https://www.summitracing.com/parts/c...make/chevrolet
but Many steps hotter is Comp 312H special cam duration is BOTH Advertised 312* while 260* @ 0.050" lobe lift ... in a 350, it's really a race cam: crappy-no idle YMMV https://www.summitracing.com/parts/c...make/chevrolet
AFAIK, 'Advertised' is usually interpreted as AT either 0.004" OR 0.006" lobe lift. YMMV
no actually it runs cooler than the previous engine that was running advanced timing. But that is because I switched to the RPM version of intake and had the headers hot coated. That might be why anyway.
