tripower float adjustment seal question
Old Dec 30, 2019 | 12:58 PM
Jims427400's Avatar
Jims427400
Default tripower float adjustment seal question
I have done this before but it was many years ago and I'm old and can't remember how to replace the round float adjustment gasket on top of the carb. Do I remove the nut and not turn the screw or the other way around?
Thank you all,
JIm
Old Dec 30, 2019 | 05:00 PM
suprspooky's Avatar
suprspooky
Hold the nut and remove the screw. The nut has a double D hole and will lift off, you'll need both the upper and lower gaskets.
I would check the float level after replacement.
Old Dec 30, 2019 | 05:59 PM
Jims427400's Avatar
Jims427400
Thanks suprspooky,
I guess I had forgotten that I need 2 gaskets. I bet I still have extras of both cause I remember them coming in a box of 6 or something like that.
Old Dec 30, 2019 | 06:19 PM
lars's Avatar
lars
When you replace the gaskets, cover the new gaskets with a light layer of grease by rubbing them between your fingers with a little grease. This will allow you to make float adjustments by turning the screw and the nut without tearing the gaskets.
Lars
Old Dec 30, 2019 | 06:29 PM
sug's Avatar
sug
2020 Corvette of the Year Finalist (stock)
C3 of Year Winner (stock) 2019
I put some grease on my gaskets (as recommended by Lars )and now I am not needing new ones every time I adjust the floats
Old Dec 30, 2019 | 06:33 PM
Jims427400's Avatar
Jims427400
That's a great idea Lars. Thank you very much.
To tripower float adjustment seal question
