Fuel Air Ratio
Yes I know,,, and I've been told all my life,,, I think too much and I'm ****. Guilty! 🤔
If you're running pump gas, which has 10% ethanol in most parts of the country, you don't want to hit 14.7 at idle or cruise. You need to richen it to the low 14's at idle and light-throttle cruise, and around 12 - to low 12's at WOT.
Lars
These gauges are pretty dumb, and will scale by a constant from lambda. I've actually conversed with the people who built my wideband setup (FAST) and they use a simple scaler.
If a car is running at stoich for E0, E10 or E85 the gauge will show 14.7 even though the actual quantity of fuel and air is vastly different depending on the blend. Some may allow you to change the scale, of course.
I actually chased my tail for a while trying to tune my very first VE table, shooting for E10 stoich, using that as the target AFR and pumping it into error calculations to correct the cells. When I switched to lambda math for calculating error I had the VE table tuned in a couple quick drives (minus WOT).
I am running a 15.0 target for cruise, low 14s for idle and mid 12s for WOT on my SBC400. The higher cruise helps with emissions which is one challenge unique to me in CA.
