Engine smoke when whacking throttle
Old Jan 11, 2020 | 01:09 PM
Triton170's Avatar
Triton170
Default Engine smoke when whacking throttle
Hope some of you smart engine guys can figure this out. 78 resto mod with a SBC 350 crate short block with Edelbrock aluminum heads. Engine has less than 250 miles on it. When I whack the throttle there is a buff of white smoke out of the right side header. Not continuous smoke but just a buff. Also a small amount of what looks like water droplets comes out of the header. All plugs look good except #4 & #6. Both are black and a little wet. Compression check and all cylinders are between 150 and 160. #’s 4 & 6 are at 150. Leak down test was negative. Cooling system pressure test was good. Engine runs strong except for the smoke and #4 & #6 plug issues. Because of the tests I don’t think it is a cylinder head. I used ARP head bolts and sealant on all bolts, at least I think I did. If I missed one could a head bolt without sealant cause this? Any ideas??
Old Jan 11, 2020 | 02:12 PM
jackson's Avatar
jackson
Test coolant again ... perhaps also test for presence of combustion byproducts,
walks like a duck ... quacks like a duck ... it's a duck
water droplets ........ white smoke
In addition to comp check, have you performed a cylinder leak-down test ?
were both of block's decks milled/resurfaced ?
If heads were used, was each milled/resurfaced ? If New heads, was each checked for flatness/scarring ?
Which head gasket (brand pn) was used ?
Did you install with any self-applied sealant/coating. ? ... if so, which ?
Old Jan 11, 2020 | 02:40 PM
Triton170's Avatar
Triton170
Did leak down test on all four cylinders on that side. All results were good. Did the chemical block test for coolant contaminates - negative. Also loosing mo coolant. New GM crate short block. Edelbrock heads - both checked flat with no scaring. Edelbrock 7361 gasket set as recommended by Edelbrock.
Old Jan 11, 2020 | 03:09 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
You have an engine issue. Tests were negative. Time to pull the head and do a visual inspection.
Old Jan 11, 2020 | 04:00 PM
7T1vette's Avatar
7T1vette
Cylinders #4 & #6 are the center two on the right side. I would surmise that you have a stuck heat riser valve (stuck closed) and that those two cylinders and the head gasket got really hot and the gasket let go. White smoke when engine is revved. See if the heat riser valve is stuck. If so, you can fix it....or you can just drop the down pipe and cut the valve butterfly off of its shaft so it can't happen again. If you don't drive the car a lot in cold weather, there will be no loss of function...just a little longer for carb to heat up.
How do I know this? Don't ask.....
Old Jan 11, 2020 | 05:04 PM
HeadsU.P.'s Avatar
HeadsU.P.
You never mentioned any coolant loss. So lets look elsewhere. Because all the coolant pressure tests seem to get a passing grade perhaps its another fluid being burned off.
Is this an automatic? There is a Intake vacuum port between cylinders 6 & 8. A vacuum line from your Intake might run down to the tranny modulator. Some do, some don't. If the modulator is defective, it will allow ATF be sucked up into the Intake, then to the closest cylinder (6). That would explain the fouled plugs.
If that ATF is burning, its most likely going to be white steam also.
Old Jan 11, 2020 | 05:34 PM
MelWff's Avatar
MelWff
Is the engine fully up to operating temperature and the car has been driven when you observe the white smoke and water droplets?
Old Jan 12, 2020 | 09:45 AM
Triton170's Avatar
Triton170
Thanks for the help so far. Smoke appears only when I whack the throttle and no noticeable smoke when idling or driving. It smokes like this when cold and when up to temperature. Car runs at about 200 degrees and has never gotten over 210. Headers so no heat risers. Automatic with the modulator vacuum is attached to the intake just in front of the distributor. Had a little weather issue yesterday so it will be later today before I can get back to it. Also #4 & #6 plugs are a little oily.
Old Jan 12, 2020 | 10:49 AM
HeadsU.P.'s Avatar
HeadsU.P.
The vacuum port on most SBC is fed from the Intake Runner on the # 6 cyl and that cylinder only. So I have no explanation of a fouled #4 from any ATF being introduced from the tranny.
When I first read your post, I was leaning towards a faulty Intake gasket seal allowing coolant in at two adjacent cylinders. But you mentioned #4 & #6. No coolant passage port there. So now you are back to the head gasket question. But that too seemed to pass the test. IDK
Old Jan 12, 2020 | 01:14 PM
jackson's Avatar
jackson
Regardless 4 or 6 or 3 or 5 ... OP should pull the trans hose & inspect for fluid inside it.
Old Jan 12, 2020 | 01:56 PM
Triton170's Avatar
Triton170
Pulled the trans vacuum hose - dry. I guess now it's time to pull the head.
Old Jan 12, 2020 | 03:24 PM
HeadsU.P.'s Avatar
HeadsU.P.
Not so hasty. Let some members think on this first.
Is your coolant level dropping?
Getting back to post #1. Yes, if some of the headbolts did not receive thread sealant and cooling system builds pressure, coolant could work its way into the combustion chamber. But that would be a head gasket issue also.
Before I went to the trouble and expense of pulling the head, I would drain-off some coolant into a clean bucket. Pull the passenger Valve Cover. Remove at least the one head bolt between cyl # 4 & # 6 and apply ARP thread sealant, retorque. And maybe the headbolt on the bottom row too. Those are difficult to get at.
Old Jan 12, 2020 | 08:48 PM
diehrd's Avatar
diehrd
What type of break in driving have you done and for howlong ? Also what oil is in it 10w what , and I hope its not synthetic .
Old Jan 13, 2020 | 09:11 AM
Triton170's Avatar
Triton170
Coolant is not dropping. Running 10W30 Lucas Hot Rod high zinc oil (flat tappet cam). Engine has about 250 +/- miles of break-in type driving. Nothing hard just a few mild road miles. No hard acceleration or high RPMs. Will try pulling/re-sealing/re-torquing a few bolts (one at a time) between #4 & #6 to give that a try.
Old Jan 13, 2020 | 06:42 PM
HeadsU.P.'s Avatar
HeadsU.P.
Something tells me its not the head gasket. Maybe just a hunch.
A blown head gaskets symptoms can go two ways. Sucking coolant into the cylinder for one.
Blowing gases into the cooling system via the block is two.
Having said that, remove the Rad Cap and with a slightly high idle, observe the coolant as it passes by the Rads fill opening. Any unusual bubbles going by?
Old Jan 13, 2020 | 07:39 PM
diehrd's Avatar
diehrd
You have to load that motor up the rpm scale varying it constantly , Put it in 3rd at a low speed and make it climb an incline down shift to 2 or 1 and force the motor to slow the car down . Never drive it like its a sundry drive to church . You might simply have 2 cylinders that did not seat the rings ..
Old Jan 14, 2020 | 02:06 PM
Triton170's Avatar
Triton170
More information. I pulled the intake today and noticed the intake runners for #4 & #6 are visibly cleaner than the other runners. All others have some gas residue on them but #4 & #6 are clean and shimmy as they were when I put this thing together. The exhaust ports for #4 & #6 are black and sooty. #2 & #8 are clean. Will dig further tomorrow when I pull the head.
To Engine smoke when whacking throttle
Old Jan 14, 2020 | 03:33 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Did the gasket look like it was sealing at #4 and #6? Is there witness marks of oil on either side of the old intake gasket?
I was going to say throw a vacuum gauge on it, but you have already removed the intake.
It would not hurt to hit the coolant system with a pump up tester......this will eliminate 100% having to remove the heads as you have performed the leak down already........leak down is pushing out against the fire ring during the test......but when running you have vacuum and pressure of course.
Jebby
Old Jan 15, 2020 | 01:04 AM
jackson's Avatar
jackson
OP
? has anyone done any porting to head or intake ?
Unless you see that something's wrong with head, take head to auto machine shop and have them Zyglo check for crack / leak ...
... check/test its rocker stud holes for same ... have shop pressure test the head. Do likewise with intake manifold.
Closely inspect bores 4 & 6 when their pistons are at Bdc.
Closely inspect block's deck for fine crack ... especially between 4 & 6. ... and at any water holes.
Old Jan 15, 2020 | 09:14 AM
HeadsU.P.'s Avatar
HeadsU.P.
You mentioned in the first post, you have Eddy aluminum heads.
Jackson might be on to something here. So the question now is:
Do the Eddy rocker studs thread into #4 or # 6 port? If so, were they sealed with a thread sealer? On some brands, the threads of the rocker stud are actually visible looking through the port. Or if extensive grinding (porting) was done, someone could open up the port TOO MUCH, exposing stud threads.
Also, when you removed the Valve Cover, was any milkshake substance present anywhere on the head?
