C3 Battery Cable Connection
Old Jan 26, 2020 | 07:38 PM
Boomer_54's Avatar
Boomer_54
Default C3 Battery Cable Connection
I bought a 71 that has been sitting for a couple decades. I need a new side connection battery however, the connection size on the battery is larger than the bolts on the car connection cable. I have checked all the major auto supply stores but haven't been able to find a replacement battery that can accommodate the car cable bolt. Unfortunately, I don't know the sizes, just that the battery connection is larger than the bolt on the car cable.
Any thoughts or suggestions??
Old Jan 26, 2020 | 08:06 PM
Pzark's Avatar
Pzark
Can you open up the holes in the cable and use the larger bolt?
Old Jan 26, 2020 | 08:36 PM
MelWff's Avatar
MelWff
Agreed, buy the correct bolts
Old Jan 26, 2020 | 11:03 PM
TimAT's Avatar
TimAT
If my old memory is correct, the battery bolts are 3/8, coarse thread 1/2 long. The heads of those bolts use a 5/16 wrench and they have a large washer made as part of the bolt.
Old Jan 28, 2020 | 05:59 PM
jackson's Avatar
jackson
I hate the standard BOLTS used in side post ... they're so short they tend to pull out threads in battery
I used a good cap screw ... and a good Nyloc nut .... and dielectric grease ... stick the cap screw through the terminal and just bottom & snug cap screw into battery ...
... then hold the head of cap screw with a wrench while snugging the nut against terminal ... slide a short piece of hose over the bolts. Did same on my DD pickup. Been working great for me. YMMV
Not so different from studded main caps w/ windage tray.
Old Jan 28, 2020 | 07:34 PM
SteveG75's Avatar
SteveG75
Same system I use. Of course, I have replaced all my battery cables with bigger 0/1 cable that I got at West Marine so no longer have the stock terminals.
Old Jan 29, 2020 | 06:47 PM
Boomer_54's Avatar
Boomer_54
Thanks that sounds reasonable. The car is in the shop now but I will give your recommendation a try when it comes back.
To C3 Battery Cable Connection
