18" wheel - 9 or 9.5 crazy price....
I see many images and write ups by guys running 18 x 9.5 rear wheels.
I am looking at Torq Trust IIs the price difference between 9" and 9.5" wide is significant more than double on the sites I am shopping.
I'm thinking just run 9s.... but nobody does.... I am newer to C3s is there a reason I only see guys running 9,5?
You have to use some common sense. If a tire manufacturer gives you a recommendation wheel width don't you think that you should follow them?
You should also go towards the wider number. I have 10 inch front and 13 rear
https://www.tirerack.com/tires/tires...omCompare1=yes
At the time of purchase 285 mm width fell within the lower end (9") of Toyo's suggest rim width range - as does 275 mm section currently......
PROXES T1 SPORT
The reference sports tyre. Aspect Ratio: 30/35/40/45/50/55Tire Size Tread Depth (mm) Overall Diameter (mm) Overall Width (mm) Approved Rim Width Range (inch) 275/40ZR18 (99Y) 8 678 279 9.00-9.5-11.00
PROXES SPORT
Answering the need for superior handling, new Proxes Sport was designed as a focused, sports performance tire.Tire Size Tread Depth (mm) Overall Diameter (mm) Overall Width (mm) Approved Rim Width Range (inch) 275/40 ZR18 (99Y) 7.7 677 278 9.0-9.5-11.0
Sorry I didn't mean to step on any toes. I was only talking to the original poster about wheel choices.
My advice has always been to choose the tires you want, then wheels, and the best flares when they figure out that they can't fit it in
No problems for me George - it just goes to show that you need to be careful with selection of tyres in more areas that just fitment. I decided to only source tyre sizes that were available for vehicles that were reasonably popular so there wouldn't be future availability issues (and better prices). Rears at were same size as one of the supercharged Jags - (then Toyo and others discontinued 285/40/18 size a few years later!) 255/45/18 was a TVR size - and we know what happened with them (or more accurately what hasn't happened with them).
https://www.corvetteforum.com/forums...on-advice.html
I think 9.5 is about the widest you can fit without significant modifications, so that's what gets run.
