REPLACING CYLINDER HEADS
Old Nov 19, 2002 | 01:09 PM
Oldguard 7's Avatar
Oldguard 7
Default REPLACING CYLINDER HEADS
When replacing heads, is it really necesary to put non hardening sealant (permatex No 2) on the threads of the head bolts or does this only apply to cast iron heads.
Old Nov 19, 2002 | 02:42 PM
glen242's Avatar
glen242
Default Re: REPLACING CYLINDER HEADS (Oldguard 7)
If the bolts go into the water jacket, as on the SBC, you must put a sealer on the bolts. Aluminum or iron heads don't matter.
