1982 Cruise Control Servo Cable
Old Feb 11, 2020 | 02:25 PM
1982CCE's Avatar
1982CCE
7th Gear
Default 1982 Cruise Control Servo Cable
Anybody have a part number for the cable or know where to find one? It's the cable that runs from the servo to the TBIs. Thanks
Old Feb 13, 2020 | 10:47 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The original part number was 14040578, it is discontinued. Currently there is no vendor for this part and it's made from what we call Un-obtanium. Good luck
Willcox
Old Feb 13, 2020 | 12:01 PM
1982CCE's Avatar
1982CCE
7th Gear
Thanks for the info! That is very rare stuff unfortunately.
Old Feb 13, 2020 | 01:03 PM
L-46man's Avatar
L-46man
1982....I'm an Engineer and a do-it-yourselfer....I have a gut feeling that you can source the parts individually and rebuild what you have. Even swagged on ends and crimps can be un-crimped and un-swagged.
Mine still works but when it craps out...that's what I'd do.
I get that question asked a fair amount....Is this a 'business opportunity'???
Along the same lines I have an antique boat...the control cables went bye bye....I just rebuilt them with the old ends and new cables.....boffo!
Unkahal
Old Feb 13, 2020 | 04:00 PM
7T1vette's Avatar
7T1vette
You might be able to swap-out the servo/cable with a salvaged one from that vintage GM car. They all saw the same amount of throttle movement and used the same level of vacuum. If the servo is functional, you just need to attach it as needed. The control head will determine when the vacuum level is increased/decreased and stabilize the set points.
Old Feb 13, 2020 | 04:12 PM
2TONE82's Avatar
2TONE82
Yup, I'd take it off and go junk yard shopping! Pick up a couple, who knows, you might make a buck or three for your troubles later. GM used a lot of parts across vehicle lines. Good luck!
To 1982 Cruise Control Servo Cable
