Need expert advise
Old Feb 24, 2020 | 08:15 AM
kensrod's Avatar
kensrod
6th Gear
Default Need expert advise
Hi everyone. Im member for forum for several years .
I need my project process recommendations.
I’m motorcycle mechanic . But not expert for corvette .
i have 1969 L68 4speed convertible all matching number car.
My baby got flat cam lobe trouble right now .
I am thinking remove motor from chassis, then replace cam , lifters etc ...
My tranny seems ok , what is faster way pull out motor from chassis?
Thanks .
Old Feb 24, 2020 | 10:13 AM
Pop Chevy's Avatar
Pop Chevy
2021 C1 of the Year Finalist - Modified
You don't have to pull the engine to change a cam. However you can pull the engine without the trans. I prefer to pull as an assembly.
Old Feb 24, 2020 | 10:42 AM
jackson's Avatar
jackson
You're a mechanic ... bike motors typically built with even closer tolerances than C3 motors ... you're a mechanic.
If you have the space, gear & time ... suggest pull motor ... gage & inspect everything ... and freshen it.
Since it's a 4 speed, crossmember probably Not removable ... but bellhousing bolts are close-quarters too ... six of one, half-dozen of the other.
Old Feb 24, 2020 | 12:13 PM
L-46man's Avatar
L-46man
Ken;
1.You can pull the radiator and hood and change the cam with the engine in the car.
2. You can pull the engine and leave the tranny.
3.Depends on how deep down the rabbit hole you want to go.
Unkahal
Old Feb 24, 2020 | 05:49 PM
kensrod's Avatar
kensrod
6th Gear
Thank you for quick response .
Im just wondering .when I remove front cam chain cover,oil pan gasket dose not stick with cam chain cover ?
Old Feb 24, 2020 | 06:10 PM
cabman72's Avatar
cabman72
If it were me, I'd pull the motor and freshen everything. You can replace the cam/lifters and next year the rings start smoking. By doing everything you know its done and don't have to worry about it. Then you can spend your time and money on other things, like suspension, interior, weatherstripping.............. It never ends
Old Feb 24, 2020 | 06:13 PM
HeadsU.P.'s Avatar
HeadsU.P.
Two different gaskets.
You are suppose to drop the oil pan a smidge to remove the timing cover. Trouble is, there is no such thing as a smidge. All the oil pan bolts must be loosened then pry the snot out of the pan to get it to drop. Meanwhile, you have broken the seal between pan & block anyway. And the idler arm has to be dropped to get the pan off.
There are ways to remove & reseal the timing cover and never touch the pan. I have done it, but not proud of it.
Old Feb 24, 2020 | 06:18 PM
jackson's Avatar
jackson
coin toss. Best to drop or partially drop pan.
Get yourself a one-piece oil pan gasket ... Fel-Pro OS 30061T is correct for 69 Big Block & OE pan ... comes w/ handy "snap-ups" for easier install.
In chevy sbc/BBC talk:
It's a timing chain
It's a timing cover
Old Feb 24, 2020 | 06:31 PM
righthanddrive's Avatar
righthanddrive
Take the engine out. Otherwise you are leaning on the fenders and nosewhile working., resulting in cracked paint or worse.
Old Feb 24, 2020 | 07:12 PM
7t9l82's Avatar
7t9l82
Either way.but pull the pan it isn't hard and clean the pan out clean as much inside as you can.
Old Feb 24, 2020 | 07:38 PM
kensrod's Avatar
kensrod
6th Gear
Thanks a lots comment !
I will do this next week either on car or pull motor out .
Old Feb 25, 2020 | 01:01 AM
Little Mouse's Avatar
Little Mouse
BBC are hard on cam lobes with flat tappet cams, regardless if hydraulic or solid do yourself a favor and use a modern PR0 55 cam core. We did not have this good stuff to work with back in the 60s and 70s. Lot more work but were me pull the whole engine apart clean it up inspect everything. Could be other stuff on it's way to failure just has not happened yet.
Old Feb 25, 2020 | 11:21 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Use break in oil to break in the new cam and make sure you use a high Zinc and phophate oil to keep you r new cam alive, just buying oil at the 7/11 will kill the cam again. Lots of posts on oil here, I use Mobil1 20w50. Its made for old flat tappets and its really cheap at Walmart. I buy it buy the gallon and fill old quart bottles to keep the motor topped of.
I pulled the timing chain cover and had to replace the entire pan gasket, I use the felpro single piece and Ultra black to keep it sealed. You can do everything with the motor in if you have a small lift or can get the entire car up on stands, which I dont like to do. I have a quickjack and I use it for everything, its worth the $1200 buck investment.
Old Feb 25, 2020 | 12:20 PM
jackson's Avatar
jackson
Default pan gasket instructions
Fel-Pro OS 30061T is one-piece and correct for 69 Big Block & OE pan ... comes w/ handy "snap-ups" for easier install when under car.
Ensure pan's rails are flat & true ... a half-hour under good lighting w/ a ball pein hammer and a wood block can do it.
Everything must be clean & dry. Not a trace of old gasket/sealer.
Best to closely follow factory instructions for above "PermaDry" OS 30061T Felpro one piece gasket.
If it says to put rtv in Only the corners then so be it.
With too much rtv, that slickens rails and gasket can't get traction and can be pushed out of position when tightening.
YMMV
Old Feb 25, 2020 | 01:10 PM
gkull's Avatar
gkull
To R&R and engine. I NEVER remove the hood. It just adds hours and possible paint damage. I kinda strip everything off the motor. leave the radiator in. support the front of the trannywith a floor jack so I can move it up and down. I use a hoist coming in from the side of the car since the hood is on.
Old Feb 27, 2020 | 12:00 AM
kensrod's Avatar
kensrod
6th Gear
Get ready
Old Feb 27, 2020 | 08:41 AM
GUSTO14's Avatar
GUSTO14
Ken, the one thing you haven't mentioned is, what cam you're going to replace it with?
Consider this, the only thing worse than going to the trouble to replace the current cam is going to all the trouble and finding that you have the same problem with the new cam. By all means consider a hydraulic roller cam. Break-in will be a snap and even a mild roller will free-up and likely add, some additional power. No need to go radical, just a good cam, with similar lift to what was in there will be well worth the effort.
In the end it may cost a bit more (at this point it's all relative), but the results will be worth it.
Good luck... GUSTO
Old Feb 27, 2020 | 04:48 PM
kensrod's Avatar
kensrod
6th Gear
I have previous owner report . He said installed little aggressive camshaft on 2005 .
so I choose comp cam 268 with flat tapper combo .
Cam shaft break in . Yes . It’s most important thing for this .
thanks .
Old Feb 28, 2020 | 12:41 AM
Little Mouse
thanks .
is that there extreme cam with the real fast rate.
To Need expert advise
