PCV addition, Type engine
Old Feb 25, 2020 | 05:01 AM
Quackster's Avatar
Quackster
Default PCV addition, Type engine
Recently acquired my first Dream car and I need a little advice. Please, before asking me to do a search thread on the pro's and con's of a PCV. I have and the conversation can take a life time to get through. LOL
For starters, the engine I have is not a matching numbers engine, it has been changed out by a previous owner. The serial number on the right side(passengers side) of the block is completely bare except a Z4 stamped on it. I did some research on it and I am a little confused about the type engine. Anyone have any insight on what the Z4 represents? I have found a little info about a ZZ4, but not Z4.
Second, this engine does not have a PCV system, only two breathers and I want to install one to prevent the emission from entering the engine bay. The only available vac. port I can find on this Eldebrock intake and carb. is the one in the back where the vac. assist is connect to the break system. I had planned on installing a T junction here but I thought I would get you experts advice on doing so. Will it effect my braking system if I add a PCV connection to the hose from the brake canister? Dang, wouldn't you know I would find a tread on PCV after posting this thread. But please any new info would be appreciated.
Old Feb 25, 2020 | 05:53 AM
derekderek's Avatar
derekderek
Boats usually do not have PCV or vacuum advance. But all intakes should have the spot where a PCV port goes. Some have a big vac port on the bottom rear of the carb base.
Old Feb 25, 2020 | 08:52 AM
Bikespace's Avatar
Bikespace
We are happy to overlook not searching for an answer first, but the Forum can help you much better if you post a few photos of you car, engine, and carb.
Old Feb 25, 2020 | 11:43 AM
Quackster's Avatar
Quackster
Thanks for responding, How ever I did do a search on the PCV but so many yes I do and no I don't are confusing. Will try using a Y spltter on the brake vac. hose and see what happens.
Old Feb 25, 2020 | 11:50 AM
MelWff's Avatar
MelWff
why dont you donwload the installation manual for the particular Edelbrock carburetor you have. The manual will clearly explain to you what port to use for the PCV.
Old Feb 25, 2020 | 11:59 AM
jackson's Avatar
jackson
https://www.corvetteforum.com/forums...post1601010517
the cover w/ PCV is plumbed to manifold
the other cover is plumbed to air cleaner assembly base.
Old Feb 25, 2020 | 06:02 PM
Quackster's Avatar
Quackster
I will look into the installation manual for the Carb. it is just everything has been used up, I either have to add a 4 port fitting or Tee it into another. Thanks for the advice.
Old Mar 9, 2020 | 11:09 AM
Quackster's Avatar
Quackster
I installed the PCV on the engine. I thought they were two crankcase breathers on the valve covers but actually there was just one, the other was a cap. After installing, the engine runs just fine and I am glad that I installed the valve. I know others run without it, but I like not dealing with the mess and the emissions I have in the engine bay.
Old Mar 10, 2020 | 01:26 AM
7T1vette's Avatar
7T1vette
The PCV system is harmless, simple and robs no power. It merely is a GOOD way to eliminate any engine-created oil vapors from messing up the engine compartment (oh, and from messing up the air ). Whether you are "green" or not, the PCV system is a 'good' thing.
Old Mar 10, 2020 | 10:06 AM
SteveG75's Avatar
SteveG75
Go here and read. I updated to the ME Wagner valve. Great unit.
http://mewagner.com/
Old Mar 10, 2020 | 08:30 PM
Quackster's Avatar
Quackster
Great read. I had a few oil leaks when I drove the 80 home. Plus transmission fluid leaks and solved that issue really quick, had to remove 1 and 1/4 of fluid where it had been over filled. After I installed the PCV system I haven't had the chance to check for leaks. But I am sure I will find they have stopped or greatly reduced. An old mechanic told me about the PCV and the issue with leaks years and years ago. That's why it puzzled me why the PO had removed it and depended on a single valve cover breather. Just had to decide on where to actually install it on this baby..
Old Mar 11, 2020 | 09:38 AM
jackson's Avatar
jackson
Why does bubba do what he does? ... combo of Ignorance. & monkey see-monkey do.
Old Mar 11, 2020 | 10:49 AM
gkull's Avatar
gkull
r
You really might want to read up on all the negatives of inducing a large vacuum leak like a 3/8ths fitting below the back of the carb from a valve cover breather! It is a combination of burnt exhaust gasses, water, and oil mist. It's not an aid to healthy combustion like oxygen rich fresh air! LIke Exhaust gas recirculation The real problem is that it is variable on engine vacuum. You can't adjust and jet a carbs air fuel ratios with a variable vacuum leak of totally contaminated air.. To be correct at WOT with very little vacuum you would be lean at high vacuum. Don't ever claim that it Robs NO Power!
Problems. It also coats your intake valve stems with oil/carbon/sludge buildup. So over the life of the motor your have less and less port flow. They run additives in pump gas to try to clean the intake valves.
The most effective HP adders are crank case vacuum pumps. Run about 16 inches of vacuum in the crank case and out through a catch can and filter. You wouldn't believe the amount of water and sludge you suck out of the crank case.
Old Mar 11, 2020 | 12:11 PM
gkull's Avatar
gkull
If you really feel the need to go green my 79 came with the large valve cover vent to the base of the air filter. That way it is venting inside the air filter. I've also used those vent type air filter bases on open element K&N dropped base filters.
Old Mar 11, 2020 | 01:18 PM
jackson's Avatar
jackson
uhhh ... should vent From ac base (not into it) ... then into VC ... then thru motor ... then out opposite VC ... thru PCV ... to Bottom of carb/manifold ,,, that way blowby is Not pulled thru carb & fouling it. That's how GM implemented it.
The OE GM vent in ac base typically has a small odd-shaped OE "filter"
Old Mar 11, 2020 | 02:42 PM
gkull's Avatar
gkull
That thing you showed is for a stock type enclosed air cleaner base/assembly. Open element is into the bottom plate inside the air cleaner. right from the valve cover breather so it is sucking fumes from the crank case. they were used in conjunction with a PVC smaller dia off the passenger cover. I see what you are saying that it would be a fresh air draw...… If the small pcv valve is flowing enough to draw through the other valve cover which isn't the normal case. with any miles on a motor the blow by is pressurizing the crank case. So it ends up going out to the air cleaner also. I eliminated the PVC valve and just used the vent for many years.
Maybe at no load idle, pvc might be able to draw fresh air through. but not under a working load of less vacuum and more blowby
Old Mar 11, 2020 | 03:38 PM
jackson's Avatar
jackson
Mr. George, me thinks your argument is with the General.
There's a lotta ways to skin the crankcase ventilation cat & I've re-engineered things as well; hasn't always been the best solution. I'm sure whatever you've come up with suits you.
Me and plenty others have plumbed breather hoses into header collectors ... bernoulli ... it works OK on race cars w/ lotsa velocity in collectors ... but Not good on street.
Race car ... go spend a small fortune on a 4-5 stage dry sump and/or vacuum pump ... race car.
Assuming motor's Not a smoker ... For a stock or non-race app, suggest GM's configuration works very well.
But if it's a smoker, motor's got bigger problems than an OE PCV system.
Assuming a properly working GM PCV "pull-thru" configuration ... suggest most crud on backside of valves is from worn seals/guides/rings.
FWIW ... motors w/ GDI don't wash ports w/ gas vapor & nor do GDI valves' backsides get washed ... so increased crud build-up is an unintended downside to GDI ...
... to help attenuate, some makers employing hybrid of both direct & port injection.
Old Mar 11, 2020 | 04:25 PM
jackson's Avatar
jackson
above PCV
Fat (Left) end sticks into valve cover: when manifoid vacuum Sucks valve Open, vapor is Pulled From Skinny (Right) end of that valve and into motor at carb or manifold via manifold vacuum.
There is typically much Less vacuum (negative pressure) at Periphery of Air Cleaner Base than at manifold vacuum port.
Manifold vacuum Pulls Fresh Air INTO the motor From that small odd breather filter that's typically Inside and at Periphery of AC Base.
https://www.autozone.com/repairguide...00c15280083688
First Four figures depict OE PCV systems
FWIW, the folks who designed the GM PCV system did so Before I fell off a turnip truck.
To PCV addition, Type engine
