A little help for the electrically ignorant, please. Took my mini starter to the Autozone & their machine says it's drawing 18volts. That's bad, I'm told. What causes it to do this? Is this a repairable thing or is it junk?
Your draw should be measured in Amps not volts. How can it pull 18 volts on a 12 volt system. A 12 volt battery can muster up about 13 volts and that is about it. The GM manual says free speed 9 volts and 54-80 amps. Don't know if this helps or not
What seems to be the problem with your mini-starter?
If there's an issue, take it to an auto electric place. I once had one of those places repair the power tilt motor for my boat. Those Autozone guys are generally weak in this area of knowledge.
Re: Stupid Question--starter current draw (page62)
I dunno. Didn't know there was a problem, actually. Bought it at a garage sale, cheap. Figured it was probably buggered, but thought what the hell. The autozone guy put it on their machine, it spun, sounded fine to me. He pointed to the meter & it was pointing a the number 18. He said, "it's pulling 18volts, it's bad." I'm too ignorant to know exactly what that means!
Try the "plug 'n play" approach. Plug it into your car (i.e., install it) and see if it works. Those guys at Autozone don't even know what the word "buggered" means (or "bollocks" for that matter) :lol:
The potential difference, or voltage, is a product of current and resistance. If it's somehow letting too much current run through, then the potential difference would be very high and the battery would not have enough voltage to juice up the starter. If it is in fact pushing 18 volts, my assumption would be that it's bad. I don't know what would cause the increase in current(or the increase in resistance, for that matter), but were you having problems with the starter not working before? (Why is it off the car?)
-Steve
PS V=iR, where V = voltage, i = current in amps, and R = resistance in ohms.
Re: Stupid Question--starter current draw (Pacin'California)
Steve --it's off the car 'cause it was never on the car. Garage sale purchase. Thanks for the explanation--that makes it seem a little more reasonable. I think I will run it by another shop and see what they can tell me.
Page --c'mon now, you know better than that! I'm way, way too lazy to stick the thing in there just on the chance it might work. :D
In the real world (our shop), with a VAT machine hooked up (Volt-Amp Tester) we typically a see 130 - 200 amp draw @ 10.5 volts under load - i.e. engine cranking. On the floor (free spin - no load) I'm guessing anything over 80 amps or so would be too much.
You need to find a shop or parts guy that has an amp clamp (typically clips over the positive cable) on his equipment so you can measure both amps and volts simultaneously.
Basically, with a gear reduction starter, if the solenoid engages properly and the thing spins free, try it.
If you do change it out, KEEP THE OLD ONE!, especially if it's original.
