Can't stab distributor ??
Lars
Jebby
Before
After, appears to be off a few degrees
Before
I use a clear distributor cap to demonstrate this to guys.
wether it's points or HEI, we have the 'sender' actuated by the dizzy shaft, witch is obviously driven fixed synch with the cam.....so we rotate outside case/frame of dizzy to fine tune the timing, other than affecting the position of the dizzy frame, there can be no affect to overall performance.....
If the distributor mainshaft does not have the chamfer on the oil pump "tongue" on the end of the shaft, it will be hell to engage. You don't need a lathe - just grind a 45-degree chamfer on all 4 sides of the "tongue" carefully on your bench grinder. It will then engage with the pump drive shaft.
Lars
Jebby
The clocking the two gears is a different issue and secondary to this.
Normally, if you don't like the installed clocking, you pull the distributor up and shift it over "one tooth" to get it right. Since the distributor has 13 teeth, each "one-tooth" shift will rotate the resulting installed clocking of the distributor roughly 28 degrees in the block. The L79, and several other applications, don't have 28 degrees worth of range for setting the timing without the housing (vacuum advance) hitting something. By installing the gear correctly, it allows the installed clocking to be correct within 1/2 tooth, or 13 degrees.
On the HEI units, it's nice to have the distributor installed so that the square top-mounted coil ends up being "square" in the engine compartment once the timing has been set. If the gear is installed 180 out, the distributor will usually end up "cocked" in the engine compartment, which just doesn't look right. With HEI engines, it's a cosmetic thing for **** people like me who like things to look nice...
HEI with the gear installed correctly with the dot pointing same direction as the rotor. Once timed, the distributor is "square" and clean in the engine compartment. If the gear is rotated 180 degrees, the same timing spec will result in the distributor being rotated 13 degrees from this position. No effect on performance or ability to set timing - just won't "look right":
Lars
When it fires, the rotor tip will not align properly with the towers. Kinda like the first part of the video.
When installed correctly, it will act like the second video., where the rotor is properly "dancing" around the posts as it advances.
I knew it couldn't affect timing because once the distributor is in the hole and the housing is tightened down, it is what it is regardless of the gear.
It is ironic because I am assisting installing a Sniper EFI on a ex-TBI 89' K5 Blazer 350.....and we are using a large cap HEI to fire it....but all of the guts have to be rewired and mechanically locked out....the most important being the Vac advance as it moves the reluctor and I had to buy this thing to set up initial reluctor phase relative to #1 on the cap......I am phasing the reluctor with this:
Jebby
If you look at the two rotor position pictures that the OP posted, the rotor position appears to be 14 degrees off not 28 degrees off.
Leading me to conclude the gear is pinned-on 180 degrees out
From what you are describing with the rotor 14 distributor degrees off from the post, the timing would be off by 28 crank degrees. So, turn the base of the distributor 14* and both the timing and rotor phasing would come back to where they should be.
I run into crap all the time that screws things up. Sometimes I lose cause and affect.
Case in point, a GM vs a "Brand X" shaft.
The difference can mess up your "Now why the hell..........??
Since retiring and spending more time with my spouse, sometimes I feel aliens are sucking my brain dry.
