I notice that the RPM needle will not start moving until the car is going 40 mph or so then the tach goes to 4500rpm - 55rpm quickly when going 55mph or so. So it's totally not reading accurately. Any idea?
I would check the distributor tach connection at the distributor(tan wire). also right at the distributor there is a tach filter (I believe it's a white wire). Check to see if that connection is good.
You're getting some kind of activity, so it's not dead. You can buy a tach circuit board(if that's the issue) for like $50 if you do it yourself. But let's eliminate the basic stuff first.
I checked the wiring and both connections look good.
Where can I purchase the circuit board and how much work is it to replace? Thanks
Reason: address misspelled words
I have a 79 as well..
mine did not work when i got it..
Pics help of your filter at distributor etc..many on here can help better..
willcox walked me through mine at ask willcox a question thread.
willcox also backed me up and helped diagnose why my new board fried!!
i changed cap rotor and coil..suggest you may want to as well..since then no issues of burning up boards...
willcox even calibrated my tach..
i bought new board new filter..from him..
if you have a filter try bypassing it to see if that fixes it first.
79 goofy year for tach imo..mine reads perfect til warm the reads low about 3-500 rpm at idle and flops up when starting..oil good too..
other than that works perfect..
