THM-350 loose shift shaft
Old Feb 28, 2020 | 10:07 AM
MGC/D_7601's Avatar
MGC/D_7601
Default THM-350 loose shift shaft
Hi all, I have a 76 C3 with an L-48 and a THM350. I was driving it last night for maybe 20 minutes, ran absolutely fantastic, shifted real smooth, and then when I got back to my garage, I moved the shifter into reverse and nothing happened. I played with the shifter and found reverse as well as drive and park but the shifter is now real loose, I cant feel the neutral or 2nd gear detent and the shift shaft has a lot of in and out play on the transmission case. When I get home from school im gonna drop the pan, ive read that the shift shaft bolt backing off can cause problems like this. Can it? What else should I look at? Can you tighten this bolt with the valve body in place? I keep finding conflicting information. Thanks in advance.
Old Feb 28, 2020 | 10:30 AM
bruiser's Avatar
bruiser
St. Jude Donor '15
You don't have to remove the valve body to get to it. I have replaced mine.
Old Feb 28, 2020 | 06:12 PM
7T1vette's Avatar
7T1vette
Your problem is likely due to a problem with the shift cable (between shifter and transmission), the cable linkage, or a bracket problem. While an internal problem could be in play, it is much more unlikely.
Old Feb 29, 2020 | 12:23 PM
caskiguy's Avatar
caskiguy
https://www.chevydiy.com/gm-turbo-35...hooting-guide/
Great books to own by the way.
To THM-350 loose shift shaft
