Staerting Problem
Old Feb 28, 2020 | 03:41 PM
red topless gator's Avatar
red topless gator
Default Staerting Problem
My friend just bought a 1976 C3 manual trans. It ran the first day but then just died. Now when you try to start it all you hear is the solenoid clicking. Put new battery in and tested alternator, was fine but still wont start. Any ideas?
Old Feb 28, 2020 | 03:46 PM
jackson's Avatar
jackson
WAG
battery cables and battery-chassis ground
MelWff's Avatar
MelWff
How did you test the alternator if the car wont start?
Did you pull the starter and bench test it?
Old Feb 28, 2020 | 03:54 PM
red topless gator
Took the alternator off and had it tested.
Old Feb 28, 2020 | 07:16 PM
OldCarBum's Avatar
OldCarBum
How was it running up to the point that it died?
Fuel in the tank?
Plugged filter or sock?
Pull the air filter and pump the throttle.
Do you see fuel spraying from the squirters?
12V at the starter and what voltage at the coil?
When you turn the engine over, do you have spark at the plugs?
Could be as simple as the coil is shot.
How does the rotor and cap look?
Old Feb 28, 2020 | 07:42 PM
red topless gator
Thanks for the reply's guys, going back to work on her tomorrow and will find out more.
Old Feb 28, 2020 | 08:42 PM
sr'71's Avatar
sr'71
turned out my starter was dead
Old Feb 29, 2020 | 03:10 PM
red topless gator
Yep, starter was bad and was also out of gas. Got it running. Thanks.
Old Mar 1, 2020 | 08:11 AM
derekderek's Avatar
derekderek
Ground wire on my 75 right below battery box.
To Staerting Problem
