Fuel
Old Mar 1, 2020 | 01:07 PM
crap's Avatar
crap
Default Fuel
What fuel octane should I put in my 1975 corvette stingray? Is 87 ok?I believe that’s what the handbook says,Thanks
Old Mar 1, 2020 | 01:53 PM
jackson's Avatar
jackson
So long as it retains its relatively low OE compression ratio (& hasn't been modified w/ hi-comp pistons/heads) ... 87 OK.
Old Mar 1, 2020 | 09:03 PM
crap's Avatar
crap
Thanks alot
Old Mar 2, 2020 | 10:30 AM
kodpkd's Avatar
kodpkd
Just don't make the mistake thinking that higher octane fuel has more power. As mentioned, if your engine doesn't have higher compression, putting extra high octane in it will actually give you LESS power.
Old Mar 3, 2020 | 12:10 PM
vince vette 2's Avatar
vince vette 2
You didn't note if it's an L82, so I am guessing that it's not. However, if it is, the base timing is 12 degrees vs. 6 or so for the L48. On my 80, L82, owned since new, I found that 87 octane would ping at 12 degrees. 89 or 90 worked fine. Today, as I don't drive it that much, I use 90 ethanol free.
Old Mar 3, 2020 | 02:02 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Set the timing correctly and see if it pings with 87.......when I say correctly, throw the manual out. Use Lars' papers to set timing for performance and drivability.......stock specs were not really specs at all.
Jebby
Old Mar 3, 2020 | 05:07 PM
Mrvettenick's Avatar
Mrvettenick
Do you still have the EGR working? That would make a big difference too?
Old Mar 3, 2020 | 05:50 PM
Bikespace's Avatar
Bikespace
Jebby
Octane will cover up problems.When I first got my L48 80, I has to run 93 to prevent run-on/dieseling. She ran HOT. I did the @lars tune, and ran her enough to clean out some of the carbon, and I can get by with ethanol-free 87. The sidepipes are much cooler now, too. I don't think the timing changed more than a few degrees, but it made a difference.
So email @lars, and experiment.
Old Mar 3, 2020 | 06:41 PM
crap's Avatar
crap
Old Mar 4, 2020 | 09:33 PM
crap's Avatar
crap
To Fuel
