1980 gauge question
Old Mar 9, 2020 | 10:01 AM
nearflack's Avatar
nearflack
Default 1980 gauge question
New circuit board, low fuel light, clock, and lights work. Other gauges don't cleaned main ground and replaced negative battery cable. Cleaned ground on drivers side pillar. Any suggestions?
Old Mar 9, 2020 | 01:24 PM
SwampeastMike's Avatar
SwampeastMike
Check the "GAUGES" fuse. It's top-center in the fuse box. Difficult to see and even more difficult to access.
Old Mar 10, 2020 | 02:23 PM
nearflack's Avatar
nearflack
I will check the fuse but I think it is ok unless I shorted something out when putting the cluster back in. Thanks,
Old Mar 10, 2020 | 06:51 PM
Street Rat's Avatar
Street Rat
That fuse is a bitch to get to.
Old Mar 10, 2020 | 07:32 PM
nearflack's Avatar
nearflack
Fuse was good but there is some corrosion on one contact. Didn’t have a fille smalle enough to clean. It will do it tomorrow. It’s a lot easier to get to with a/c duct removed
Old Mar 10, 2020 | 07:38 PM
Street Rat's Avatar
Street Rat
Seriously
I purchased these on eBay to pull the fuses out of my '81. Works well on the circuit breakers also. I guess it could be used for other things too?
Old Mar 10, 2020 | 08:07 PM
SwampeastMike
It;s still a pain to access--let alone clean--with the entire dash removed!
Old Mar 10, 2020 | 08:17 PM
nearflack's Avatar
nearflack
I’ve been through so much with this restore this is just a bump in the road!
Old Mar 12, 2020 | 09:27 AM
vince vette 2's Avatar
vince vette 2
Originally Posted by Street Rat
Seriously
I don't think I want to know what those "other things" it might be used for are.
Old Mar 15, 2020 | 09:36 AM
nearflack's Avatar
nearflack
Fusewas good but there was corrosion on one of the contacts. Cleaned it and all work now except temp but that’s a broken connector on the sender. Have a replacement on the way!
To 1980 gauge question
